Question about this 'welding job'
Old May 8, 2014 | 08:10 PM
H0|\|DA's Avatar
Icon6 Question about this 'welding job'
Just got a 2001 Honda Accord Coupe.. Having a bit of wobbling issues from the passenger rear and found this in the back on the sway bar...
Versus this on the driver rear..
Would appreciate some feedback, what needs to be replaced and if it is even safe to drive atm. Thanks!
Old May 9, 2014 | 05:38 AM
HellaFab's Avatar
Default Re: Question about this 'welding job'
that wouldn't cause a wobble.
Old May 11, 2014 | 03:31 AM
Str8 outta Cliff's Avatar
Hard to tell from the pics but it does look suspect. Car may have been involved in an accident to cause that kind of damage, would definitely want to take a close look at the entire rear suspension.
I agree the sway bar mounting shouldn't cause a wobble since it mostly prevent body roll but if the bracket that rear suspension link mounts to is structurally compromised it could most definitely cause an issue
Old May 15, 2014 | 12:32 PM
BlueTeg's Avatar
Looks like one of the previous owners ran a stiffer swaybar and the bracket the swaybar mounts to, tore out/way from the chassis.
Old May 17, 2014 | 07:09 PM
-RedneckDave-'s Avatar
Working
Check the wheel bearings while you are back there. That could cause a wobble.
rickscrx
Dec 19, 2011 05:08 AM
liljohna103
Dec 8, 2007 08:34 AM
TheWalrus
Sep 12, 2006 12:28 AM
Nextelbuddy
Apr 1, 2004 01:18 PM
uncleben
14
Mar 24, 2003 10:27 AM
