1989 Honda Crx Si Overheating
Old May 8, 2014 | 09:27 AM
lhmchl's Avatar
Default 1989 Honda Crx Si Overheating
I have a 1989 Honda Crx Si. The radiator was leaking and I had it replaced. Then about a month ago, the car overheated. The mechanic replaced a hose, but then the temperature started rising faster than normal and always stays at the middle of the temperature gauge. Yesterday, I was driving it and the temperature gauge went up past the middle of the gauge. Any suggestions on what is wrong with the car?
Old May 8, 2014 | 06:30 PM
ownedevo10's Avatar
Default Re: 1989 Honda Crx Si Overheating
Might be dumb but did you check to see if you have coolant in the car after it over heated yesterday? Maybe you still have a leak somewhere..
Old May 8, 2014 | 08:44 PM
SpokaneSpeed's Avatar
Check coolant level, check for leaks or signs of leakage, and check to make sure the fan is coming on.
Old May 9, 2014 | 06:31 PM
StayKrafty's Avatar
Air in the coolant system could also be the culprit.
Old May 9, 2014 | 06:58 PM
Tyson's Avatar
leaks happen in multiple places after the first one.
im dealing with it on another car i own. you stress the whole system and youll find all the weak spots.
keep looking for leaks, bad clamps, dried up coolant, etc.
Old May 10, 2014 | 10:25 PM
nicknack25's Avatar
After you check for more leaks, does your engine heat up only at stops, or whenever you are driving?
harrysingh123
Honda Civic (2001 - 2005)
Nov 10, 2017 11:03 PM
Mitsuoko
Honda Civic (2006 - 2015)
Dec 15, 2016 10:03 PM
BigTrak
Feb 25, 2009 03:05 PM
simplypinoyy
23
Aug 6, 2004 03:06 PM
tsjeff
May 17, 2003 10:56 AM
