Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
TL or RL pistons on J35A4?
Old May 7, 2014 | 07:11 PM
gmcuajo1's Avatar
Default TL or RL pistons on J35A4?
Have been searching on this and other forum about swaping TL or RL pistons on the J35, but haven't found a clear answer and which one of those two to use for higher compression and more power.
Some says that the RL pistons should be used because of valve clearance and the fact that the factory pistons are "alluminum forged". On the other hand, other people say that both are almost the same with no difference at all.
Also nobody mention which TL or RL pistons. What year, model, and out of what motor?
If anyone here knows please post or let me know the correct thread. Remember that is for J35A4. If know about any other J35 variant, please comment too.
Old May 7, 2014 | 07:16 PM
gmcuajo1's Avatar
Default Re: TL or RL pistons on J35A4?
Also if you have info about J-Series engine dimesnssions please post here. Like piston compression height, rod length, head cc's, etc.
Old May 30, 2014 | 12:45 PM
nihad's Avatar
Is there a better J series forum then this no body on here knows anything about J series I know the J35A4 has a cast non forged crank unlike the TL RL and Ridgeline the A8/A9 I believe its just the stroke that is different on the engines... I got a question for you do you know if the A4 would have the same holes on the block so the Ridgeline A8 mounts would work on the A4... I got a J35A8 and having some major issues with walls scoring due to a bad cat... LMK
Old May 30, 2014 | 05:09 PM
WanaBeFaster's Avatar
which j series are you looking for info on specifically?
devious_yeti
May 2, 2016 07:30 PM
xDicktonesx
Dec 26, 2005 05:50 AM
rice is nice
May 18, 2005 08:45 AM
djnikko
Aug 24, 2004 09:48 AM
