fouling spark plugs instantly
Old May 7, 2014 | 05:25 PM
br8crumb's Avatar
Default Solved - foulin plugs
heres a part #2 to my stupidity so im curious if there linked.
where the fuel first enters the rail, cyl 1 an 2 are fouling really quickly with carbon, cyl 3 is clean, and cyl 4 which is farthest is looking lean.
now the question, if i had a fuel leak on the end of the fuel rail, not the fpr or gauge port, would that have the pressure gauge read wrong? *installed next to fpr* and actually have higher pressure entering the rail and then fading out across all 4 injectors?
fishin for answers b4 i start messin around tmrw. just a idea im dancin with atm lol
******* leak at end of rail through gauge off which is inbetween cyl 3-4 so cyl 1 and 2 were running higher ps then needed which fouled the plugs
Old May 7, 2014 | 05:42 PM
holmesnmanny's Avatar
not sure what kind of car you have but if it has egr you should clean the ports and the valve
Old May 7, 2014 | 08:30 PM
br8crumb's Avatar
Default Re: fouling spark plugs instantly
only thing iv touched before issue was fuel rail/fpr and only thing i see wrong is a leak at the end of cyl 4 aka farthest away from where fuel enters
since u ask bout egr, technically i had 1 even though it was nvr plugged in and i deleted it when doing manifold swap. ur basic n/a b18 ls build thats been pieced together part by part lol
Old May 7, 2014 | 09:04 PM
turbomaniac's Avatar
if you had fuel leak it would smell very much, so i think it is difficult not to understand it. This that you are facing is common to all one throttle and 4 in line engines. its not enough air the problem (due to limitations at one throttle and inlet manifold design) and not the fuel.
Old May 8, 2014 | 07:39 AM
br8crumb's Avatar
personally think i have too much air no offense. 70mm tb port matched to skunk2 manifold. reason the fpr went on so i can mess around since im still obd0
and the fuel leak is ever so slightly, but it might be enough to **** up wat i did. waitin 4 rain to stop so i can go mess around
Silvertc
Sep 23, 2010 09:49 AM
bakomack
11
Jun 5, 2009 01:18 PM
SINISTR
Jan 29, 2008 07:46 PM
skUnK2jdm
Jan 30, 2007 12:00 PM
