Stock GSR cam advice
Old May 7, 2014 | 04:45 PM
DelSolMike's Avatar
Default Stock GSR cam advice
Doing some maintenance on my 01 GSR and figured I would put some new cams in. I was thinking the Skunk2 tuner 1's. The motor will remain stock-ish. I may throw a small snail or Jackson supercharger on at a later date... Will the tuner 1's be my best bet for a stock GSR with simple bolt ons? Is there a better choice?
How it sits now:
01 GSR
ITR Intake arm
68mm throttle body
Skunk2 IM
4-1 header
2.5" cat back
Hondata S300
Thanks
Old May 7, 2014 | 05:15 PM
rexB20vtec's Avatar
Default Re: Stock GSR cam advice
yea tuner 1's will work good with basics bolt on's, witch cams are better it really comes down to what you want to do with your car, auto x, drag, etc.. ,
Old May 7, 2014 | 05:22 PM
DDTECH's Avatar
Stock valvetrain? Overall goals?
Old May 7, 2014 | 06:58 PM
DelSolMike's Avatar
I may upgrade the valvetrain. Stock block. Stock compression. No headwork. No porting.
I just want fun, reliable car. I'll probably autox it and do track days. That's about it. Nothing serious. Like I said, I may throw a small snail on it. No more than 275whp max. Just want insant power. Or I may go the Jackson Supercharger route. Any sort of boosting wont happen for at least another year. I have way too much work to do on the monster d16 del sol build. Until then, just looking for a little extra go.
Old May 8, 2014 | 06:24 AM
TheShodan's Avatar
Moderator
Well, you won't find a JRSC in one piece anymore (not new with all the brackets and such, anyway.). autox , won't require much considering you're only in 2nd and maybe 3rd gear depending upon the cone structure..
For circuit (road race), the Tuner 1s will be fine, and can still work with a small turbocharger setup.
Old May 8, 2014 | 06:46 AM
GagnarTheUnruly's Avatar
I've got Blox A's on a stock B18C1 and they are fine. It is only street tuned so I cannot say how much power they make over stock but they work on 10:1. Tuner 1s should be "drop in" but I would advise stiffer valve springs.
Old May 8, 2014 | 06:56 AM
DDTECH's Avatar
I dont think a Tuner1/BloxA should even be considered. You'll be more happier with a powerband/torque in low/midrange from a bigger primary type camshaft. Look at least into some type of Stage 2 camshaft.
Run nitrous, over a root style blower. My opinion.
Old May 8, 2014 | 09:34 AM
93egSLEEPER's Avatar
Pro 1's came to mind for me...
Old May 8, 2014 | 10:32 AM
DelSolMike's Avatar
Why? Don't the stage 2's do better with higher compression? I am not building this motor at all except supporting valvetrain for potential cams...
No way am I ever running nitrous.
Old May 8, 2014 | 10:33 AM
DelSolMike's Avatar
Again, I thought these cams will not perform well with stock GSR compression?
Old May 8, 2014 | 11:34 AM
Says who?
Compression is ONLY 1 part of the equation.
Tuner 2's in stock GSR's kick ***, just have no bottom end. The pro 1's won't peak as much, but the mids will be much stronger. Pro 2's are a different story
Old May 8, 2014 | 12:25 PM
DelSolMike's Avatar
Another thought is to call Web and see what they can come up with for me.
Old May 8, 2014 | 12:57 PM
whitesihatch's Avatar
I agree with a lot that's been said. With stock gearing run the tuner 1's or the 2's. You just have to choose what trade off you want to make.
I have stock block gsr and run the toda b's due to my gearing great setup.
Old May 8, 2014 | 03:47 PM
DDTECH's Avatar
Stock GSR compression like stated is one tenth the equation.
I've done a lot of tunings on stock itrs, Stock GSRs, even stock b16's with mild to bigger camshafts, and they work great, don't be mislead by what you read, rather what others have in real world experience.
You seem to be looking towards what a pro1/Stage2 type camshaft will get you, I sent you a PM.
Old May 8, 2014 | 03:48 PM
DDTECH's Avatar
Why wouldn't you run nitrous?
Old May 8, 2014 | 07:45 PM
TheShodan's Avatar
Moderator
Nitrous filling stations are few and far-between lately. Plus, I wouldn't like depending upon "the bottle" just to have fun, when a blower will let me have fun any time I want.
Old May 8, 2014 | 08:03 PM
h2.4's Avatar
Nitrous is not my fav. Trying to regulate bottle pressure, refilling, its like a temporary fix. I would rather go with a supercharger, turbo setup where you don't have to worry about heating and pressure to keep stuff consistent. And forget about trying to get it filled in a pinch. Way worse than trying to find e85. Drag setup only when trying to spool your oversized turbo. I would look for cams with a smooth low to high cam transition, unless you need to pass emissions. Pro1's or others.
Old May 10, 2014 | 10:42 PM
d15Beta's Avatar
https://honda-tech.com/forums/showth...4#post49694734
post #33 is a graph of wat i did way back
buddyclub3 has 250@0.050 dur. so its close to s2s1 or pro1
its a usdm itr but should be close to ur gsr, it dynoed with a filter
and full exhaust... no velocity stack and pipe extension to tweak results
just how it runs on the street.. HTH
Old May 10, 2014 | 10:43 PM
d15Beta's Avatar
it also used ITR valvetrain.. but an upgrade would def be safer
Old May 13, 2014 | 05:13 PM
bambam's Avatar
Id advise against any camshaft upgrade untile valvetrain is upgraded. If you go this route, and the head is to be removed, you can go with a thinner HG, and mill the head .010. Maybe even go with flat valves at that point. Otherwise, I really like buddy club spec 3+ on a stock gsr w/ valvetrain upgrade, or like others have mentioned, S2 tuner stage 1's.
Old May 14, 2014 | 07:37 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
BC3 > Tuner 1s
Tuner 1s are small... they are carb legal in CA, that should tell you something.
Old May 15, 2014 | 04:50 PM
WASP1's Avatar
i made good power on tuner 2 and crower/supertech valve train for a year on a very similar setup before i dropped a valve in cyl #4 last week. im 99% sure dropped valve is due to installation error not a defect in the parts used.
tamparican
Feb 26, 2012 07:46 PM
tazeat
Engine Management and Tuning
Jul 16, 2010 04:27 PM
gerbcrx
Nov 18, 2006 04:32 PM
jmoss1987
Jun 19, 2006 05:17 AM
jdmjeff
Mar 12, 2006 06:29 PM
