oil leaking
I have a all motor high compression and I don't know why my car Is leaking oil everything on the car is new and all good but once I drive it for a few oil starts to come out.. what can stop this will a oil catch can help me out????
Na valve cover dry it from the back cuz if u Jack the car up and look all under the car is wet like if it from every where. But what I don't get is I did a oil change left the car running and nothing But once I drive then it starts and after a few day you can smell it and see smoke from it hitting the exhaust. But if u park there nothing left on the floor
Hmm I would start checking around oil filter-black crankcase breather box, pcv valve and any of the lines going into the block, sometimes they not tighten, are all the hoses new or used, also there is a grommet where the pcv goes into the black box, that should be changed as well. Just a few suggestions. My engine is high compression and I had to replace the grommet and ta da no more leaks. Catch can wouldnt hurt, what is your setup?
I got. B20v that black box in the back the b20 don't come with it but everything else is good
Lsv kit? Like oil sandwich plate, oil line and tapped head? Perhaps that could be your issue. Not enough oil pressure at idle to cause a leak, (theoretically) but enough pressure under load to cause a leak.
Yea lsv kit all good head too it the top part of the engine dry just the bottom half wet
is that a golden eagle lsv kit? ive seen their o rings on the sandwich plate leak like a bitch more than once.
your not running a moroso oil pan by any chance are you?
I had a similar scenario with my 93 Prelude H22A. I saw RTV gasket on my oil pan so immediatly assumed thats what was leaking and spraying oil all over. I replaced it and then a week later i lifted it and saw oil in the same spot, but the new gasket looked perfectly fine. I was replacing my clutch and as soon as i pulled it i discovered it was the rear main seal.
relentlesstech
Jun 22, 2016 11:18 AM
drock4688
Jan 14, 2009 12:34 PM
djmatix
Feb 7, 2005 07:58 AM
