Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
RPF1 Valve Stem Install
Old May 7, 2014 | 12:45 PM
kevinmcc2's Avatar
Default RPF1 Valve Stem Install
Does anyone know what order the parts go?
Pic shows the parts.
Does it go rubber gasket,wheel,rubber gasket, washer, nut, nut?
Old May 7, 2014 | 02:06 PM
97emsedan's Avatar
Default Re: RPF1 Valve Stem Install
The black rubber washers are to be in contact with the rim. The cupped steel washer goes against the nut...look at the setup on the far right, but imagine the rim between the rubber washers.
Old May 7, 2014 | 05:03 PM
kevinmcc2's Avatar
Cool was just confused cause the washer has an indent on one side.
Are these pretty reliable or would you suggest going with the ones that just push in.
Old May 8, 2014 | 06:17 PM
97emsedan's Avatar
The indent goes to the nut, leave a smooth flat surface for the rubber seals to rest on...
TomCat39
22
Mar 14, 2015 05:50 PM
mac_24_seven
Mar 22, 2013 09:00 PM
allricedout
Jun 26, 2007 09:12 PM
Willard
Aug 17, 2006 12:26 PM
Mach69
17
Nov 23, 2005 07:01 PM
