2000 Prelude Sh
Old May 6, 2014 | 12:22 PM
skunk24's Avatar
Icon6 2000 Prelude Sh
Hey guys i need some help. I have a 2000 prelude sh that I'm having trouble with I thought it was the clutch so I brought down the tranny and clutch & flywheel, pressure plate everything was still good but the fork part is in the correct spot but it's loose idk if it's missing a part or what. I also changed both slave & master cylinder and still the same problem. Plz HELP!!!!!
Old May 6, 2014 | 01:22 PM
r_Senik's Avatar
Default Re: 2000 Prelude Sh
please state your problem. and you'll probably get more help in the tech forum.
Old May 12, 2014 | 10:55 PM
gstrudler's Avatar
+1 actually need to know what the problem is. Also, I'm assuming you're talking about the clutch fork; it is normal for it to have a lot of play without the slave cylinder putting pressure on it.
I'm assuming you're having what you believe to be clutch problems. Since you've already got the clutch and flywheel out, you might as well change them if you weren't planning on it already, especially being on an SH.
hndacord02
Feb 11, 2011 02:47 PM
cockeyedcricket
Sep 25, 2009 12:48 PM
jdmeg9
Feb 22, 2009 02:44 PM
Coroner
Mar 20, 2006 06:04 PM
EXspeedyaDOTCOM
Nov 30, 2003 04:57 PM
