edelbrock cams and type r valve spring question
I got a question that I cannot find a answer for so I thought I would post it up here to see if anyone else had an answer..I am installing a Edelbrock Exhaust Cam 4730 in my GSR B18C1. Now I was told that this cam is similar to a Type R exhaust cam, and I know that the Type R uses a Double Valve Spring set up on the exhaust side that the GSR does not because of the bigger lift. So I am wondering if I could put in the Type R Exhaust Valve springs in with this cam and be ok. I have some laying around and if it works I will just put those in with this cam, otherwise I really don't feel like spending $300-500 on valve springs for the little amount of power I am going to gain from it. And Im sure someone will ask why only the exhaust cam, is because I am supercharging it, and the best set up is a GSR intake cam with a Bigger Type R or other exhaust cam.
The Edelbrock cams aren't that big. But if you are worried about it then source a heavier spring. Like Suptertech's 80 lb seat pressure offerings. They are still affordable and most manufacturers offer multiple spring rates to choose from.
Chillinit
18
Apr 17, 2006 06:58 AM
