99 Accord Dash Instrument Panel not working
Old May 4, 2014 | 04:35 PM
shanetheboland's Avatar
Icon6 99 Accord Dash Instrument Panel not working
Hi there,
I just purchased a used '99 Honda Accord. The dash light instrument panel (odometer, speedometer, rpm, gas gauge) are not working.
The check engine light, srs, and abs lights all work. It's only the gauges that don't work.
I have checked all the fuses with my eyes, and with a multimeter.
What else could be causing this?
p.S. The driver side trunk tail light fills up with water because the seal is broken. Not sure if this could be causing the problem in some way.
Thank you
Old May 4, 2014 | 11:24 PM
holmesnmanny's Avatar
should be a 10a fuse in the driver side kickboard fuse box assembly that might be blown
Old May 7, 2014 | 05:12 PM
Lost Again's Avatar
Default Re: 99 Accord Dash Instrument Panel not working
I would beg to differ with this comment.
Reading the wire diagram the power to the abs, cel light, ect.....and the power to the Speedo, temp, gas gauge all come from the driver dash fuse - #9 7.5 amp.
So if you turn the key to "on"/pos II and the cel comes on and then goes off - that would confirn that pin B11 to the gauge unit is getting power from the fuse listed. However you start the car and the Tach does not work - we are chasing a differnt issue.
Old May 7, 2014 | 05:27 PM
ya mine is a 10a so i figured it would be somewhere in that ballpark
Old May 10, 2014 | 07:54 AM
Lost Again's Avatar
Its cool
The 6th gen's are a bit "funny" - then add they changed the gauge cluster mid gen and more fun comes
Scraper
Jul 12, 2016 09:02 AM
tigerbait
Oct 22, 2007 01:46 PM
ilovemydc5
May 22, 2007 12:45 PM
jdmhagengsr
Sep 24, 2006 09:30 AM
JDMDC5888
Mar 27, 2006 01:26 PM
