Replaced plugs/wires/cap, now car will not start
I just did a tune up today, and replaced my spark plugs, wires, distributor cap, and rotor, and now when I try to start the car it cranks over very very rough, but does not fire, as far as I know everything is in the correct firing order, what could be the issue? I did not mess with the timing whatsoever
Basic required information: Model, year, and list of modifications. Parts of the rules, and required in every thread.
Post a picture of your distributor and wires, aiming down the valve cover like this:
I'm sorry, I'm in the middle of a parking lot on my cell phone, and things aren't working the way they usually do on the computer.
I have a 97 civic (d16y7), no mods - I'm trying to figure out how to post a picture from my phone
Well, your wires are in the wrong order. You have 1 going to 3, 2 going to 1, 3 going to 4, and 4 going to 2. If the previous picture isn't clear enough for you, here's another one from the FSM.
Your cylinders are probably flooded from all of the failing to fire. Remove the spark plugs, let it sit for a day to dry out, re-install and try again.
****, I'm in the middle of a parking lot, & I have to get my car out of here, it will seriously take a day to dry everything out? :-(
Well, if you want a quick fix, remove the fuel pump fuse, fix your wire order, and keep trying to start the car. You'll eventually burn off the excess fuel, but the continual strain won't be healthy for your starter, or your battery. Have a buddy on speed dial ready to come jump you if you kill your battery.
When facing the engine from the front of the car, left to right, cylinder 4,3,2,1. You have them on wrong. Start from the distributor position "1" and go to the cylinder that it needs to be plugged into, if there is a plug in it unplug it and leave it hanging.
You have now successfully done it every possible way EXCEPT the correct way.From how you're looking at it in that picture:
Top left hole goes to FAR RIGHT cylinder
Bottom left hole goes to MIDDLE RIGHT cylinder
Top right hole goes to MIDDLE LEFT cylinder
Bottom right hole goes to FAR LEFT cylinder
If you can't get it right after this, I'm going to assume you're either a troll, or have the spacial awareness of a 3 year old, and should take your car to a professional.
I finally got it! The problem I was having was because it's so freaking cold out here I was shaking so bad that I kept screwing up the order, the car is running fine now, thank you all for your help
