d16y7 reliability upgrades?
Old May 2, 2014 | 11:00 PM
kebragg's Avatar
Default d16y7 reliability upgrades?
Just picked up a 96 civic for 650. Got a few maintenance issues to take care of, but, I was wondering if there are any quirk these engines have? Im looking for a reliable A to B beater. Are there any maintenance parts that are the go to for these engines? anything that commonly fails? A specific part brand to stay away from? New to hondas, any tips appreciated.
Kevin
Old May 2, 2014 | 11:19 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: d16y7 reliability upgrades?
timing belt/water pump. exhaust manifolds crack by the oxygen sensor. avoid any non honda oem distributor/ignition components.
Old May 2, 2014 | 11:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
Specific brand to stay away from is easy: Anything that isn't OEM. Considering the price you got it for, I'm going to guess it's in pretty bad shape as it is. What you should do depends entirely on how bad a shape it's in, and what's wrong. We need more details if you want real advice.
Old May 3, 2014 | 04:48 PM
sanegb16's Avatar
Valve stem seals have probably never been changed. Oil pan gasket distributor o ring and valve cover gasket sets are another thing to look at
Old May 3, 2014 | 07:25 PM
tony_2018's Avatar
Fish Twig
Radiator flush, I guess when you're doing it you might as well replace radiator hoses, heater hoses and any coolant lines. Timing belt, water pump, tensioner and spring, cam seals and crank seal. From there you'll just have to wait and see if anything happens. If you plan to flush the transmission just go with honda fluid. If you ever have to replace an axle than please change out the axle seals.
Old May 3, 2014 | 11:02 PM
kebragg's Avatar
Ive made a huge rockauto parts list for a complete tune up, water pump/timing belt, valve cover/lash set, hoses, belts, and filters.
Ive tried to use all oem manufacturers. Aisin water pump, gates belts and hoses, NGK spark plugs and wires, fel pro gaskets, etc. Does this sound good? And all this for about $300! I love how cheap these parts are lol
Im buying it off a friend who has had it sitting. It has the fluctuating idle problem and a valve cover leak. Otherwise it has been solid for him. Just doesnt use it anymore and its been neglected for the past 6 months. But i need a new project.
Wouldve replied sooner, but replies arent going to my email. Will have to change that...
Old May 4, 2014 | 01:10 AM
alot of people will hate on fel pro gaskets. ive used them on many different engines with no issues at all. your belt and pump are perfect, so are the plugs and wires. the victor reinz branded composite headgasket i bought from rockauto for a 95 civic was actually manufactured by manley. go figure.
Old May 4, 2014 | 01:33 PM
tony_2018's Avatar
Fish Twig
You could've ordered most of that from HOnda online sites. If you did a price comparison its almost the same, spend the extra bucks for oem quality. I notice local honda dealers raising prices like a ************. $300 for just the timing belt, tensioner and spring. What a rip off.
user 929730482
Dec 3, 2013 09:08 PM
jwarren1904
Jul 7, 2013 10:56 PM
JDMHN8
Southwest (Sales)
12
Sep 11, 2005 06:49 PM
StatGSR
Jul 21, 2004 07:23 PM
arren123
Dec 11, 2003 09:46 PM
