Civic '98 spark shows only once when cranking
I have a problem with Civic '98, ignition coil and igniter replaced but problem is that spark comes out only once when I am cranking it.
So I am cranking it, spark shows once, still cranking but spark is not there anymore.. I dont know how to explain it better, hope you got it
Just tested yellow/green to ground and it have continuity but shouldnt have as it says in pic you provided, also when I disconnect yellow/black from ICM spark is pulsing but too weak. Also looks like injectors are not opening as spark plugs are dry after cranking.
fasteddief23
Jun 30, 2011 05:07 PM
bghayd
14
Jan 10, 2010 02:28 PM
