1997 Honda Accord - P0301 - Slight Misfire
Old May 2, 2014 | 03:21 PM
HondaNathan's Avatar
Icon2 1997 Honda Accord - P0301 - Slight Misfire
My 97' Honda Accord runs like a top, even at 283K. However, last week it just through an engine light on. I read the code and it is P0301. There is a slight misfire when light and only light throttle is pressed. If I give the car a boost, the misfire goes away.
I have already replaced the spark plugs (NGK), spark plug wires, distributor cap and swapped out all of the inner components of the distributor. Still no changes and the light persistently comes on after 8 miles of driving.
I also threw in a can of seafoam into the tank to make sure it wasn't any bad gas. I am still baffled at what the problem could be.
Any suggestions or advice would greatly be appreciated!
Thank you.
Old May 2, 2014 | 05:40 PM
holmesnmanny's Avatar
retrieve the check engine code
Old May 2, 2014 | 09:26 PM
ja97accord's Avatar
Default Re: 1997 Honda Accord - P0301 - Slight Misfire
i had the same problem with exact same symptoms, tried everything until i figured out i had a lose valve in the head, hope it isn't that bad for you..
Old May 3, 2014 | 12:43 AM
lol Not sure why I said retrieve the check engine code but sometimes I'm on the app and i might have missed it.
Anyhow, first thing I would do since you've replaced most of the ignition parts is to clean out the egr plate and egr valve. There's a howto in the faq's at the top of the forum or you can do a youtube search for "eric the car guy honda egr cleaning".
Old May 8, 2014 | 09:05 AM
Thank you for the suggestions. I have cleaned out the EGV valve and that did not resolve the issue.
JA97accord, was there a 'ticking' sound on your car before you found out it was a loose valve? I don't have any ticking sounds on my car right now and I am curious.
What are your thoughts about the fuel injectors?
Old May 8, 2014 | 10:44 AM
origamy's Avatar
Adjust valves to spec. Try to swap injector from cylinder 3 to cylinder 2. See if misfire moves to cylinder 2. If so, injector is faulty. Do a compression test. Compare compression in cylinder 3 to others.
FunkTechNician
Feb 1, 2011 02:31 PM
santron
Mar 15, 2008 06:11 PM
nicokpe
Sep 29, 2007 04:50 AM
poly35
Mar 14, 2007 06:53 AM
Hondagal
Mar 3, 2007 09:04 PM
