Code 15 need help
Old May 1, 2014 | 10:39 PM
2kdrift's Avatar
Default Code 15 need help
Car starts up perfectly and runs perfectly but I get a code 15 (Ignition Output Signal).
I have searched around but all i can find is people With bad ICM, Usually either the car will not start at all or dies while driving, My car does none of this Just cant seem to get rid of this code. Anyone have any Ideas how I could narrow down the problem? Dont feel like dropping $540 for a new Dizzy if its just an easy fix such as a $20 part. I dont have a another ICM to try either mine are all the wrong style.
Been doing alot of searching but if any one has any good info i will really appreciate it!
Old May 1, 2014 | 11:11 PM
holmesnmanny's Avatar
Default Re: Code 15 need help
You can get one of these things on ebay for like $20 or you can get one from the junkyard for even cheaper. You're lucky it's even throwing a code, most of the time it doesn't when the ignitor goes bad.
Depending on what kind of car you have, you can pull one from a 90-93 accord and it will work and these are a dime a dozen at the junkyard.
jmeyer99
Aug 2, 2007 10:18 PM
kuteboi
Jan 29, 2005 09:11 PM
crx(gator)
Apr 27, 2002 03:51 PM
