motor mounts question
Old Apr 29, 2014 | 02:29 PM
lvsdan's Avatar
Default motor mounts question
What motor mounts do i use for an ls-vtec swap in my 96 civic coupe? The cars shaking with the ones it has on there.. unknown what mounts they used when they did the swap..
Old Apr 29, 2014 | 02:56 PM
FeelTheBass's Avatar
Default Re: motor mounts question
You can reuse the stock mounts that came with the car, or buy some nice aftermarket ones.
Hasport, Avid, and Innovative are some reputable brands that sell quality aftermarket motor mounts.
Go ahead and post a pic of the engine bay and I'm sure some one will be able to identify the mounts you have.
Old Apr 29, 2014 | 03:38 PM
lvsdan's Avatar
[/IMG]
Do I use stock civic mounts or the ls mounts?
Old Apr 29, 2014 | 03:53 PM
lvsdan's Avatar
Let me know if you can see the pic..
Old Apr 29, 2014 | 04:07 PM
spontaneous123's Avatar
can't see photo
Old Apr 29, 2014 | 04:10 PM
lvsdan's Avatar
Originally Posted by spontaneous123
can't see photo
I think its only showing on full site idk why..
Old Apr 29, 2014 | 04:47 PM
lvsdan's Avatar
Bump
Old Apr 29, 2014 | 04:59 PM
NotARaCist's Avatar
I never narc'd on nobody!
It's not showing on ANY version of the site. You used the wrong URL.
Old Apr 29, 2014 | 05:13 PM
lvsdan's Avatar
http:// http://i327.photobucket.com/...ps1butextl.jpg
Sorry still learning..
Old Apr 29, 2014 | 05:21 PM
lvsdan's Avatar
Photobucket is not working
Old Apr 29, 2014 | 05:33 PM
NotARaCist's Avatar
Well uh, they didn't use ANY front torque mounts, which is kind of stupid to start with.
Maybe you should figure out WHY the engine is vibrating, rather than trying to cover it up with soft mounts.
Old Apr 29, 2014 | 05:39 PM
lvsdan's Avatar
Doesn't vibrate at idle jus around 2000 and up.. front torque mounts?
Old Apr 29, 2014 | 06:43 PM
Wdpfreak145's Avatar
There are two smaller "assisting" mounts that keep the engine from torquing under heavy load (like uphill takeoff). One is attached to the A/C bracket, which you don't have there, and the other goes to the front of the tranny. They have a bushing on the end that bolts to the underside of the frame rail on either side.
Old Apr 29, 2014 | 06:53 PM
lvsdan's Avatar
Oh I didnt know that I bought the car with the swap in it.. so that would cause the vibration under acceleration? I don't know if it matters but the car is also lowered? ..
Old Apr 29, 2014 | 10:31 PM
NotARaCist's Avatar
No, the vibration while accelerating is a motor, transmission, axle, wheel, or tire problem that you should properly diagnose and fix.
Old Apr 30, 2014 | 06:19 AM
lvsdan's Avatar
Thanks for the info i will update when solved..
Old Apr 30, 2014 | 12:31 PM
You could diagnose the wheel/tire issue by having you're tires rebalanced. Not sure about how much that would cost, but if they are already properly balanced I would assume the mechanic would not charge you.
Those are definitely aftermarket mounts, which are probably stiffer than OEM. You also don't have either torque mounts installed, which has already been said.
If the car is vibrating under load specifically, I would have to say the normal culprits are either bad alignment, bad axles, or bent/unbalanced wheels. Those are the areas that I would personally inspect first, but you could also go down the list that NotARacist has provided.
Old Apr 30, 2014 | 01:06 PM
lvsdan's Avatar
Well I was driving it today and when I'm coasting it doesn't vibrate at all.. But with the clutch pressed in and given gas the vibration comes back.. I know that one of the CV boots is torn.. But I would think it would vibrate only under a load if the CV was causing it right? Do you know if they do any modification to the mount or mount bracket (on the rear of the engine)?
Old Apr 30, 2014 | 01:56 PM
digitalvice's Avatar
Have you out the torque brackets and mounts in yet?
Old Apr 30, 2014 | 05:22 PM
So when you go to change gears (clutch pressed in to shift then given gas) when you step on the gas it vibrates? Which would mean that the car vibrates under load?
I'm pretty sure if your CV boot is torn, most of the grease has probably leaked out causing your axle to wear down (correct me if I'm wrong). At this point, you might want to replace that axle.
Old May 1, 2014 | 03:24 PM
lvsdan's Avatar
Yea I replaced the axle today still vibrating.. found that the t bracket on the rear mount has a crack half way threw it.. might be where its coming from.. would I replace it with the civic t mount or the ls t mount?
Old May 1, 2014 | 03:39 PM
NotARaCist's Avatar
You need a 99-00 Civic SI rear T bracket mount.
Old May 1, 2014 | 03:41 PM
lvsdan's Avatar
appreciate the information. .
Old May 1, 2014 | 06:58 PM
Well if you didn't replace the axle with the torn boot you probably would have run into problems down the road anyway, and you can get the EM1 T bracket at the honda dealership for like $65 or find one on ebay. I think I got mine for $50 on ebay.
Old May 1, 2014 | 07:02 PM
lvsdan's Avatar
EM1 Is that the part #?
