1999 2.3L LX ACCORD "THRUST BEARING NOISE"
Hello
have any of you ever experianced this. Has a Rear Main Seal start leaking badly and after inspection Started hearing a noise. Sounded like a cracked flexplate at idle but cleared up under load. The crank has a little play from what seems to be worn thrust bearings "Lack of oil changes form previous owner?" has any one ever done this in the car that is with the crank installed in the car. The car is a 1999 2.3L accord LX auto.
Thank you
Thank you
davgonzalez1@aol.com
Apr 15, 2008 05:31 PM
