82x89 setup looking for tips/help for more power.
Old Apr 29, 2014 | 04:28 AM
Andy8's Avatar
Default 82x89 setup looking for tips/help for more power.
Setup is as followed.
Chassis
95 civic DX hatchback
A/c removed
Spare/tools removed
150lbs driver
22x13 slicks
Head:
ITR head light port and polish
ITR intake manifold portmatched to head
S2 Alpha 70mm TB
Pro1 cams
GE cam gears
Supertech valve train and valves
3in intake to headlight
Block (ITR block)
82mm12:1 comp pistons
Manley rods
89mm crank
Arp head studs
Cometic head gasket
Exhaust
S2 Alpha header
2.5in kteller exhaust w/vibrant muffler
Fuel
93oct
ID1000cc injectors(from previous turbo setup)
Walbro 255
Transmission
99 USDM ITR
Suspension
Eibach sportline kit
Buddy Club Rear lower control arms
Car has gone 12.7@108mph with a 1.84 60ft so far. Tuned on s300 and dynoed 210/146 on a dynopack. Looking to squeeze a little more out of this setup. Any suggestions and tip are appreciated.
Old Apr 29, 2014 | 07:40 AM
TheShodan's Avatar
Moderator
Default Re: 82x89 setup looking for tips/help for more power.
Not a bad setup at all. I have something similar. Change your camshafts up to a DDTECH or a Pro2. Get more seat time and check your air pressures. Done.
Old Apr 29, 2014 | 08:26 AM
Andy8's Avatar
Thank you for the advice! I will absolutely keep practicing! I have found my best time with pressures around 8psi launching around 6800rpm. Some have suggested the performer x and toda replica header to setups similar to mine would you consider those parts worth switching to as well? Or would the cams benefit me more in this situation?
Old Apr 29, 2014 | 06:26 PM
UncleD's Avatar
To me the next logical step would be some intake manifold testing or sleeving block. A modded Performer X or 84/85mm.
Old Apr 29, 2014 | 06:38 PM
JoeBlue's Avatar
I agree with the cams being the sticking point right now.
What are you revving to?
Old Apr 29, 2014 | 08:49 PM
Charlie Moua's Avatar
change fuel type... lol
imho i would do it in this order
port match IM to tb if not yet done
pro2 or RM cams
degree in cams
change fuel type
retune with open header ... test various intake piping
i think as long as you have enough cam, stock gsr skunk2 IM should get you close to 230
whp with out completely killing your topend.
i could be completely wrong.
Old Apr 30, 2014 | 02:50 AM
Andy8's Avatar
Originally Posted by JoeBlue
I agree with the cams being the sticking point right now. What are you revving to?
The tuner set the shift light to 8300 and I shift around 8400 according to s300 and rev limiter stops me around 86XX even though it's set to 8800 on the s300.
Old Apr 30, 2014 | 02:56 AM
Andy8's Avatar
Originally Posted by Charlie Moua
change fuel type... lol imho i would do it in this order port match IM to tb if not yet done pro2 or RM cams degree in cams change fuel type retune with open header ... test various intake piping i think as long as you have enough cam, stock gsr skunk2 IM should get you close to 230 whp with out completely killing your topend. i could be completely wrong.
I apologize the IM is port matched to the TB.
Old Apr 30, 2014 | 04:43 AM
whitesihatch's Avatar
Pro 1's are garbage. Get some Pro 2's, and better intake mani, 3.5" intake, 3" exhaust.
BTW were the numbers on a roller or a pack?
Old Apr 30, 2014 | 05:07 AM
Andy8's Avatar
Originally Posted by whitesihatch
Pro 1's are garbage. Get some Pro 2's, and better intake mani, 3.5" intake, 3" exhaust. BTW were the numbers on a roller or a pack?
Numbers were on a pack.
Old Apr 30, 2014 | 09:09 AM
Pretty solid numbers!
Old Apr 30, 2014 | 12:12 PM
eDm cRxXx's Avatar
RM24 cams, 3in exhaust and performer x or s2 ultra street.
Old May 2, 2014 | 06:22 AM
Andy8's Avatar
I think I will give the performer x a trying and change to 3in exhaust for now since they are the least intrusive. Would I still see decent gains with a stock performer x or would I have to modify it?
Old May 2, 2014 | 07:53 AM
koczeka's Avatar
I would almost repeat that.
RM22 cams, 3in exhaust and s2 ultra street.
Old May 2, 2014 | 10:39 AM
SP GARAGE's Avatar
Chassis work will help you go faster .
Old May 2, 2014 | 12:21 PM
Andy8's Avatar
Any areas you suggest to change or add to for the chassis?
Old May 2, 2014 | 01:36 PM
UncleD's Avatar
You honestly think it would make sense to remove Pro1 for M22?
Old May 2, 2014 | 10:13 PM
koczeka's Avatar
Yes. m22 is about the same level as Pro2 and I like it a lot more.
U should know the REAL size of these, but it appears U don't.
Old May 2, 2014 | 10:18 PM
UncleD's Avatar
I disagree, but thats an interesting thought. I would compare the M24 to a Pro2, M22 to Pro1. Unless Robert changed something about them..
Old May 3, 2014 | 02:12 AM
koczeka's Avatar
No problem. Ask Robert. That is always been the case.
Old May 3, 2014 | 03:07 AM
Black R's Avatar
25 Year Member
Bump that up!
Where do your hp and tq peak at?
You could up your rev limiter to 9200-9500+, assuming your tune is good for that rpm range.
Cams like pro2 should still make power up there (I'm not sure about pro1's).
Old May 3, 2014 | 04:56 AM
JDogg's Avatar
It's a little motor.. I'd leave the motor be and work on the chassis and driving.. build a big motor. All the stuff needed to make the small motor fast just chokes up a big motor and you'll have to buy it all over again.
Old May 3, 2014 | 06:04 AM
Andy8's Avatar
Originally Posted by Black R
Bump that up! Where do your hp and tq peak at? You could up your rev limiter to 9200-9500+, assuming your tune is good for that rpm range. Cams like pro2 should still make power up there (I'm not sure about pro1's).
Honestly I'm not sure as the dyno graph I received stops at 8400-8500. The tune was done at EvanTuning. So I would think Jeff set the shift light and rev limits according to when the engine starts to fall off. I'm just assuming this though.
Old May 3, 2014 | 06:23 AM
d112crzy's Avatar
M22ke and s2 ultra or performer x would be the only changes to motor if you're after more power.
Post your slip breakdown.
Old May 3, 2014 | 08:55 AM
Andy8's Avatar
Here is the breakdown for my best run to date.
60'...1.841
333...5.307
1/8...8.162
MPH...85.93
1000...10.642
1/4...12.729
MPH...108.24
