Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
blinking "D" shift light of death!!!
Old Apr 28, 2014 | 06:34 PM
smurf357's Avatar
Default blinking "D" shift light of death!!!
I got a 2003 pilot awd with about 169k miles. recently about a month ago, the "D" shift light starts blinking on and off. the vehicle started jerking when it shifts. I got a transmission flush from Honda dealership thinking that was the issue. the issue went away for a few days. then the issue resumed. the catch is the light don't always come on. when the light does come on, the vehicle drives perfect like there is nothing wrong. the jerking only occurs when the light don't flash; usually jerks between shifting into 2nd and 3rd gear. Is this an expensive fix and does anyone know what this is or has had similar problems?
Old Apr 29, 2014 | 07:38 AM
TODAwhore's Avatar
Default Re: blinking "D" shift light of death!!!
Sounds like it's time for a new/or rebuild of the trans. I bet if you check you'll have one or more trans DTC's, usually a p0720/0730.
What does the fluid smell like (burnt smell)??
Old Apr 29, 2014 | 07:48 AM
95accordCE6's Avatar
Check the transmission speed sensor and trans temp sensor. The flashing d light is a fault sign from the tcu, and also check the fluid level and color obviously
Old Apr 29, 2014 | 02:21 PM
smurf357's Avatar
just had the fluid changed right after the light came on. so don't think that's the issue. is it costly to rebuild or get a new one? so is it possessible for the vehicle to act the way it is because of a faulty sensor?
Old Apr 29, 2014 | 04:48 PM
It's very possible. I would recommend diagnosing the problem rather than having the whole trans rebuilt or replaced. Have you had the codes checked as stated above?
Old May 1, 2014 | 01:16 PM
smurf357's Avatar
so any idea what sensors would cause the issue? where are those sensors located? I'm gonna try the sensors first.
Old May 4, 2014 | 12:59 PM
Jjbaehr's Avatar
It will be either the 3rd or 4th pressure switch, very common problem for the pilots, my money is on the third due to me changing more of them.
Old May 7, 2014 | 06:44 PM
smurf357's Avatar
so how much would that cost?
Old May 12, 2014 | 01:52 PM
Jjbaehr's Avatar
Parts is about 50$ from the stealership
Cameron707
Apr 11, 2017 10:17 PM
MADDIESMOMMY760
Nov 18, 2012 07:34 PM
Kris's turbo
Apr 28, 2010 05:54 PM
shrewz92
Jul 27, 2006 07:23 PM
Caramel Turtle
Dec 27, 2002 04:07 AM
