NY 1992 H22a4 Swapped LX Sedan 88,000 miles
Old Apr 28, 2014 | 02:29 PM
95Sedan's Avatar
Default 1992 H22a4 Swapped LX Sedan 88,000 miles
FOR SALE: H22A4 SWAP'D 1992 HONDA CIVIC LX MANUAL
VIN: 1HGEG8558NL063195
Looking to get 4,000$
suspension from an acura integra, all brand new parts with matching CV shafts
springs cut 1.5"
Motor is from 2000 honda prelude/transmission
OBD1 P28 Mugen chipped ECU
ARP 340LPH Stealth (factory location) fuel pump installed
New fuel pump relay/filter
New refurbished starter
new dizzy/seal set
Mr gasket translucent orange dizzy cap/rotor
New slave cylinder/fresh fluid
fresh penzoil 15w40 tranny fluid
Solid motor mounts with poly inserts (car vibrates quite a bit)
F/R upper strut tower bars
Ported/Polished TB
EGR Blockoff (emissions non existant)
4-2-1 Header/Catless test pipe full 2.25" exhaust/thrush standard muffler welded up
New driver front wheel studs
Blue rota D2 wheels
New front 10/32nd tread sumic tires
rear tires 4/32nd goodyears
new TPS sensor/harness/calibrated
now for the needs fixing:
-LF Fender
-Clutch has sometime been acting up and the car will not want to shift (TOB probably needs replacing)
-front left controls for window/locks don't work.
-passenger rear window off track.
-completely gutted interior (no headliner even)
-check engine light on
-Vtec solenoid leaking alittle bit
-MINOR rust around quarter panels
ANY QUESTIONS FEEL FREE TO CONTACT (716)997-5968 TEXT PLEASE
Old May 3, 2014 | 04:35 PM
95Sedan's Avatar
Default Re: 1992 H22a4 Swapped LX Sedan 88,000 miles
Bump
suldy
Jul 6, 2017 10:59 AM
95Sedan
Jul 4, 2014 12:03 PM
thewizardb18cr
Jun 24, 2013 10:52 PM
nacho_man
Jan 3, 2007 03:45 AM
nacho_man
Jan 3, 2007 03:28 AM
