Vacum Leak of Bad IACV
Old Apr 28, 2014 | 03:22 AM
afnan's Avatar
Default Vacum Leak of Bad IACV
I have 92 accord with 98 Accord F18B engine. Few days back i pluged ODB2 scanner and short trim was 40%. Surely it indicates vacum leak i guess.
Also When i try to adjust Base IDLE i cant. On un plugng the IACV the idle starts bouncing which makes sure there is a leak
Funny thing is there are two screws on IACV when i loosen them and moves to one extreeme and adjust idle screw i can reduce the RPM to 650 RPM not below that. When i consider it base idle and reset ecu and plug IACV, restart car. it maintains 700 rpm but when i press throttle and leave the RPM First drops to 500 and then raises very slowly to 700.
Recently I got my Injector Cleaned and Flow tested.
I have two Questions.
1. Is my IACV bad or Vac leak is causing all this.
2. Can improper Adjustment cause Vac leak?
3. When car is turned Off I Block IACV Intake, Throttle Body filter place and EGR tightly and pump air through PCV Valve it keeps on going, why?
Mike Heath
Feb 21, 2018 02:44 AM
james007
Apr 30, 2010 04:26 PM
sun_zinc
Jul 13, 2008 01:19 PM
cj7420
Mar 24, 2002 06:55 AM
