need help diagnosing electrical problem
Old Apr 26, 2014 | 10:10 AM
loveandmoney204's Avatar
Icon3 need help diagnosing electrical problem
I have a Honda accord 2002, 2.3, 4 cyl. It was wrecked within in the last few months on the front, passenger side. I have been having serious electrical issues and dumping money into it like its my job. The battery tests good. My alternator tests bad when it is in the vehicle, but when I took it out and tested it on the machine 3 times it tested good. my cables and terminals are good. I have a 1.55 amp drain, my alternator will not charge my battery, I have been told that the 2002 Honda accord has a computer controlled charging system, could potentially be the problem and the cause of the drain. I can not afford a certified shop at this time. I have no idea what to do next, any help is appreciated.
Old Apr 26, 2014 | 12:04 PM
NerfGunner420's Avatar
Default Re: need help diagnosing electrical problem
maybe the charging signal wire is not sending signal
Old Apr 26, 2014 | 03:16 PM
95accordCE6's Avatar
Was the fuse panel damaged in the wreck. It could be a loose connection there, otherwise test voltage coming from the alternator to see how many volts are going back to the battery. I believe there is also a 100a fuse between the alternator and the battery, if so definitely check that
Old Apr 26, 2014 | 05:21 PM
tim73's Avatar
Can you isolate which circuit it is? I assume you have an amp meter, as you know how much of a current draw there is. Install it, in between your negative battery post and cable, then start pulling fuses. If it is only one circuit, when you find it, teh draw will drop to closer to zero(Assuming all lights, radio and everything is off) Once you know which circuit it is, that makes troubleshooting a little easier.
Old Apr 28, 2014 | 09:14 AM
here. should of looked on the web
http://troubleshootmyvehicle.com/hon...e-alternator-1
Old Apr 28, 2014 | 09:29 AM
here you go
Old Apr 28, 2014 | 09:30 AM
here is this one too
Old Apr 29, 2014 | 03:51 AM
I found the problem it was a faulty ELD. Preventing my alternator from charging, it starting throwing out multiple check engine codes. These dual charge systems are all new to me. Thanks a lot for any input and concern everyone.
Old Apr 29, 2014 | 03:53 AM
I had 3 transmission codes, 02 censor code, and my condenser and cooling fan stopped working. As well as the additional epic p1298 code all came up shortly after I made this post.
Old Apr 29, 2014 | 03:54 AM
Thank God this is over. At least I have a new alternator and battery, as well a lot of electrical accessories :D
Lance Baker
Honda CR-V & Element
Dec 5, 2021 06:55 PM
adamc44
Mar 19, 2013 10:04 PM
PsykoMoulton
Oct 6, 2011 09:15 AM
Spud1
Apr 29, 2010 12:39 PM
logeywartooth
Sep 14, 2008 07:10 PM
