1994 ACCORD CLUTCH ISSUES?!?
Hello,
I have a manual shift 1994 Honda Accord LX. Sometimes when I shift into 2nd or 3rd gear the car will isle higher but it will not accelerate. Do i need to replace the clutch or is there a possible other issue?
Verify the clutch linkage is adjusted correctly and fully releasing. If so then the clutch is most likely slipping. A higher load on the clutch(higher gear) will place more load on the clutch and it will slip.
gtking98
Aug 22, 2011 04:14 AM
