16x7 with a 30 offset on a 95 integra sedan
Old Apr 24, 2014 | 11:41 PM
gsrturboEK's Avatar
Default 16x7 with a 30 offset on a 95 integra sedan
http://bit.ly/PxPcaW
Looking at this set for a DB sedan integra. Will I run into any clearance issues?
16x7 28 offset
16x7 30 offset.
I'm thinking about running 205/40/16 tires
Wheels are in link above.
Thanks
Old Apr 25, 2014 | 11:35 AM
OH Snap's Avatar
Default Re: 16x7 with a 30 offset on a 95 integra sedan
You should be fine.
I'm running 16x8 20s all around and I only rub on the rears every once in a while. Then again I have a thinner tire (195/40) and I am not slammed.
Old May 14, 2014 | 11:48 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
That will be perfect.
Run the +28s up front.
Old May 15, 2014 | 01:38 PM
TunerN00b's Avatar
16x7 28 offset
16x7 30 offset.
Thanks
Wrong sized tires, but the wheels should fit fine.
You should be using 205/45-16s or 215/45-16s.
Old May 15, 2014 | 02:47 PM
TypeRfit's Avatar
RESIDENT
You will be just fine, this is a 16x8 +20 with a 205/40/16. Had to roll the fenders but that's it, had minimal camber too.
Old May 15, 2014 | 09:13 PM
2LEM1's Avatar
I like to party
Community Builder
205/40 is actually the preferred size on a lowered car with wheels in that size.
205/45 is the 'correct' step size, but it will rub on those wheels.
Old May 16, 2014 | 09:17 AM
TunerN00b's Avatar
The car determines the correct tire size, not the wheel.
The Integra was designed around a 195/55-15, the stock size. 205/40-16 is too small in diameter. The speedometer is off. The odometer will slowly drift from correct over time. The reduction in diameter increases the harshness from impacts with road imperfections, and increases the rolling resistance.
I had a set of 205/40-16s and currently roll on a set of 205/45-16s. 215/45-16 have also been on my Integra. All fit fine, as long as wheels in the correct offset are used, and I've been tucking tire with all 3 sizes.
teg22
Jun 18, 2010 12:28 PM
Costco
14
Nov 20, 2008 11:04 PM
00b18b
Aug 2, 2008 06:32 PM
M2B4
Apr 1, 2007 07:49 AM
Toda Party
Jul 3, 2001 10:40 PM
