Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
'09 Odyssey electrical problems after dead battery and jump start - turn signals
Old Apr 24, 2014 | 06:11 PM
A2Jim's Avatar
Default '09 Odyssey electrical problems after dead battery and jump start - turn signals
Hi - My kids recently left a light on in the van overnight, and the battery was dead in the morning. I jump the van, no problem, however, a number of things didn't work: power sliding doors, radio, shift interlock were all dead. I hunted down blown fuses and replaced them - everything works EXCEPT, the turn signals go solid-on when the brake is applied (they work fine when not braking) and the cruise control turns off when I put on the turn signal to change lanes. I double checked all the fuses again. Suggestions? Thanks Jim
Old Apr 27, 2014 | 05:50 PM
EK FLY's Avatar
Default Re: '09 Odyssey electrical problems after dead battery and jump start - turn signals
sounds like that turn signal is getting ground from your brakes , check all your ground next to battery clean and check again
Old May 5, 2014 | 06:29 PM
A2Jim's Avatar
Thanks. I checked ground at the battery and it is clean and intact. Whatever happened was most likely caused by draining the battery and then jumping the vehicle.
1-When the brakes are applied, the LEFT turn signal goes solid.
2 -If the cruise is on, and the left turn signal is turned on - the cruise goes off (it must think I applied the brake) It's bizarre. Any more suggestions?
Broseph Clark
Feb 12, 2013 12:00 AM
Conflicted
Dec 3, 2007 06:02 PM
Senbonzakura
Honda Motorcycles
Jun 24, 2007 02:20 PM
three stars, two bars
Apr 18, 2007 08:41 PM
9311dan
Nov 13, 2006 05:44 AM
