1998 v6 automatic trans fluid
Old Apr 24, 2014 | 12:15 PM
jmanuel's Avatar
Default 1998 v6 automatic trans fluid
i checked my trans fluid
drove till reached normal temps then cycled through the gears then checked. dipstick has two holes (lower and high mark)
and my fluid is atleast an inch over? when i start car and put on reverse it jerks pretty violant could this cause this? drain fliud or try to siphon?
Old Apr 24, 2014 | 12:20 PM
tim73's Avatar
Default Re: 1998 v6 automatic trans fluid
Did you recently change it or? I would do a 3x drain and fill with geniune honda ATF.
Old Apr 24, 2014 | 01:26 PM
jmanuel's Avatar
nope this how i just recently bought it. its a good inch over top mark
Old Apr 24, 2014 | 01:45 PM
MAD_MIKE's Avatar
MM Gruppe B
It should not be higher than the high mark on the dipstick when at operating temp.
Drain and refill, you can reuse the fluid as long as the containers you use to catch the fluid is not dirty. And you may just pull out some junk while draining, which is good.
Old Apr 24, 2014 | 02:06 PM
jmanuel's Avatar
okay and to do so iknow honda atf but how much?? dnt want to overfill
Old Apr 24, 2014 | 02:08 PM
jmanuel's Avatar
idont have owners manual
Old Apr 24, 2014 | 02:15 PM
MAD_MIKE's Avatar
MM Gruppe B
What I was saying was, for now, to drain out the fluid from the pan into a clean container. Then refill your trans with that fluid to the correct level. Since you have too much you just need to refill it up til it reaches the low mark, then start the engine, let it pump and keep filling until the high mark is reached. Done.
It is not good to drive with too much fluid as the fluid may be churned up and aerated by the gears. Which will then cause excessive wear and tear.
Old Apr 24, 2014 | 04:28 PM
jmanuel's Avatar
yeah but idnt even know if previous owner had put honda atf so if ima go ahead and drain it out imight as well put some new honda atf right?
Old Apr 24, 2014 | 08:47 PM
MAD_MIKE's Avatar
MM Gruppe B
What does the dipstick say on it to use? Older 90-97s actually have 'DEXRON II' embossed on the dipstick. Main concern is to either drain the trans of the excess fluid or not drive the car until you can.
Old Apr 24, 2014 | 09:48 PM
jmanuel's Avatar
mine doesnt say anything on it.
but i looked up owners manual and it says use honda atf.
bemused
Jul 25, 2013 06:27 AM
Maurice24
Apr 30, 2010 12:39 PM
singher01
Jul 25, 2008 10:19 AM
jonathanraycamacho
Apr 27, 2008 11:28 AM
Cypher0117
May 3, 2005 06:47 PM
