Tranny Hates Reverse
Old Oct 30, 2002 | 04:46 AM
FifthGearOnline's Avatar
Default Tranny Hates Reverse
this is a problem that i have had since i bought the car but have just delt with it. Some times i will have to pump the clutch about 2-3 time just to go in reverse, and even then its difficult some times
is there anything i can do to fix this!!?!?!?
Old Oct 30, 2002 | 05:03 AM
Hondasaurs's Avatar
Default Re: Tranny Hates Reverse (FifthGearOnline.com)
I've had the same problem. Try putting it in 1st gear then go to reverse. This helps mine almost every time.
Old Oct 30, 2002 | 06:47 AM
serious's Avatar
reverse has not synchro unlike your forward gears, so if the teeth don't match up when you try and put it in reverse, it simply won't go. the easiest thing to do is, which the clutch still in, put it in first, try reverse, if it doesn't work, put it in second and then try reverse again.
Old Oct 30, 2002 | 01:23 PM
MAV3RiCK478's Avatar
try wiggling it in N a couple of times before putting it in reverse.
Old Oct 30, 2002 | 03:10 PM
Angry Joe's Avatar
That is normal
BlueStar
Jul 26, 2008 07:14 PM
vtec25
Feb 1, 2006 11:53 PM
hubjub
May 18, 2005 06:00 AM
JDM_B18C5
Oct 4, 2004 12:29 PM
BlueIntegraBoy
Jul 25, 2004 11:57 AM
