89 civic dx tranny leaking
Noticed the other day when I had my car on the lift for the first time getting exhaust work done, I had a pretty major trans leak! I cannot tell a specific place where it's coming from but that every bolt head and nut has oil on it. I tried tightening them but they're tight. Only other thing I can see if it's mainly wet from where the trans halves meet. Any way to stop this? Stop leak oil or anything of that sort? Or pull the motor and tranny and fix the oil pan leak also?
If yoiu replace them and it is still leaking, it may be your rear main seal or some seals or gaskets from your head leaking down the passenger side, only if the oil is brown.
If you overfill a Manual Transmission, it will leak out of the cv axle holes.
For auto tranny's, good luck. I actually never messed with any Honda's auto tranny. But I'm assuming its similar with the axles set up. Also check your tranny pan.
The axle shafts are not leaking. And the drain plug isn't either. It's a 5 speed. I don't see a specific place of the leak just from the shift linkage that goes into the tranny and all around where the 2 half's bolt together
Stock Car
Transmission & Drivetrain
Feb 4, 2014 06:08 AM
