does anyone have OBD1 P72 ecu circuit board diagram
Old Apr 22, 2014 | 03:35 PM
edwinie26's Avatar
Default does anyone have OBD1 P72 ecu circuit board diagram
I cant find a diagram for USDM p72 obd1 manual (of the circuit board)
reason i need it: im trying to fix a obd1 ecu i purchased.. they basically ripped me off..~$130 USD worth of rip off
fixed r77 it was nice and crispy.. track is intact
and now it shows me the mil
code 16 flashes but i know my injectors work (i have a p28 and it works fine on my jdm b18C gsr)
just need to know where a1 a2 a3 a5... and so on.. and where they plug in the circuit board.
Thanks in advance
Old Apr 23, 2014 | 12:25 PM
edwinie26's Avatar
Default OBD1 P72 ecu test for injector driver
Found it online after 20 something hours of searching. Here's the link to trouble shoot injector drivers.
im in process of trying to make this p72 work...
http://www.hackedecu.com/wp-content/...-Testing-1.pdf
Old Apr 27, 2014 | 09:13 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: does anyone have OBD1 P72 ecu circuit board diagram
I originally posted that on PGMFI, glad to see it's spreading around. that's not for the 1980 board, but they're all fundamentally the same as far as circuit testing.
Old Apr 28, 2014 | 07:34 AM
edwinie26's Avatar
thanks I had a feeling you where on here . Im in processes of looking for a scrap ecu.. would you happen to know if i can use qm1 qm2 q22 and q23 from a p06 or p28
thanks
Old Apr 29, 2014 | 06:57 PM
I'm Huge In Japan
yeah most of the components are all the same across all OBD1 models, except the extended boards for crank sensors and knock have some variations.
Old Apr 30, 2014 | 07:20 AM
edwinie26's Avatar
sounds good i want to try it but im a bit iffy... because i have a spare p06 auto virgin.. and i really dont want to scrap it if i can convert it later on
what about HIC1 looks a bit different on a p28 and a 1720 version p06
asking because my p28 is dumping gas..its giving me cyp code
and if it doesnt really matter much to srap my p06 might aswell fix both ecus
808jdm_profileEG6
Apr 28, 2009 01:33 PM
93 da9 gsr
May 18, 2007 09:03 AM
ATrin
18
Jul 31, 2006 05:38 AM
