92 Accord EX cranks but wont start
Old Apr 22, 2014 | 03:31 PM
JadedWhispers's Avatar
Default 92 Accord EX cranks but wont start
I recently replaced my head gaskets, distributer cap and rotor. Now that everything is out back together my engine will crank, but never turn over. I've triple checked that everything is plugged in and in its place, but I can't find the problem. The last couple of days it's been raining and the engines gotten wet, could that be the problem? If so, since the weather hasn't improved much lately what can I do? Also I was thinking it might be the fuel system. Is there a way to prime it? Any help would be appreciated!
Old Apr 22, 2014 | 04:05 PM
holmesnmanny's Avatar
Default Re: 92 Accord EX cranks but wont start
Check the mechanical timing, then do a compression test. If the compression test is good make sure the distributor connectors are plugged in fully.
Old Apr 22, 2014 | 11:04 PM
proman's Avatar
Assume your timing is correct, your distributor shaft may be 180 degrees reversed.
Old Apr 23, 2014 | 12:19 PM
Compression is good, connectors are all in place properly, and the distributer is off center rendering installing it 180 degrees reversed impossible.
Old Apr 23, 2014 | 12:39 PM
check for spark and fuel ... what were the compression numbers
Old Apr 25, 2014 | 12:08 PM
I got it running again, there was a lot of air in the fuel line, and I just had to prime it like crazy
Old Apr 25, 2014 | 02:17 PM
NerfGunner420's Avatar
weak fuel pump? clogged fuel filter?
Old Apr 25, 2014 | 02:51 PM
You didnt fix the problem.
gandalf
Dec 17, 2013 09:59 AM
canabiscris
Nov 18, 2013 10:53 AM
tackhammer629
Jan 18, 2012 04:44 PM
efjones9
10
Aug 5, 2010 03:31 PM
hmtcrxsir
Jul 10, 2007 11:41 AM
