A few questions about Carbon Fiber hoods
Old Apr 22, 2014 | 02:12 PM
davegt27's Avatar
Default A few questions about Carbon Fiber hoods
This was not in the FAQ
On these aftermarket hoods be it Carbon Fiber or fiberglass do you need a different hood if you have an upgraded motor like a B18?
I have a D16 now but I will go to a B18 later down the road
Thanks in advance
Davegt27
Old Apr 22, 2014 | 02:38 PM
ef2_civic's Avatar
Default Re: A few questions about Carbon Fiber hoods
Just try to get one with the hump up instead of down like stock. For further down the road when u swap engines
Old Apr 22, 2014 | 02:49 PM
alex1321's Avatar
lol youre talking about SIR hood. This hood doesnt fit the usdm front end. well it fits but the SIR headlights are longer than usdm headlights so you end up having free space between your headlights ends and your hood. It is also hard to find an SIR hood.. loll
To answer the question, if you only go for a b18 non vtec, your oem hood will fit. If you put a b18 vtec inside, you just have to space your hood up so it wont hit your valve cover. You can also remove some of the hood support under it so the clearance will be better.
Old Apr 23, 2014 | 08:51 AM
Nerdskateful's Avatar
I have a B18c in le old EF and the OEM hood hits the valve cover but does close. Also had a VIS carbon fiber hood which also hit and didnt want to press down it for fear it may crack. So that why im going JDM front lol. Im running AZ racing motor mounts.
Old Apr 23, 2014 | 09:20 AM
24TEN's Avatar
PHANTOM MENACE
There are SiR style hoods that still use the USDM style front ends.
Old Apr 23, 2014 | 09:30 AM
solorex's Avatar
Yes. VIS makes a JDM style "bump up" hood that fits the USDM front end. I have one and it provides the clearance for any B-swap.
Old Apr 23, 2014 | 09:39 AM
davegt27's Avatar
Cool thanks everyone
I am learning a lot, for one weight savings is getting pretty costly
It’s probably going to be equivalent to the cost of a B18 swap
Davegt27
Old Apr 23, 2014 | 10:58 AM
whited's Avatar
CRX God
Had to cut the support beams out of mine. I have a 98 spec B18C type R, which I believe is a tighter fit possibly. The innovation mount I have gives you ground clearance, but not hood. I believe the hasport does the reverse.
Old Apr 24, 2014 | 06:39 AM
br8crumb's Avatar
what ppl dont seem to get.. is if ur using a full size radiator it most likely will hit the hood regardless what u use if going b series.
as for the " hump " u can shove any b series in and not have to worry about clearance... doesnt matter if its vtec or a ls. ppl who have problems may just be using cheap ebay mounts that sit the motor higher.
and personally, find a real carbon fiber hood. so many fakes out there that have like 10 layers of clear coat before u hit the real cf. they tend to beach out from the sun after a year or 2 if its a outdoors car. wax comes in handy every few weeks
and if need be.. there are spacers to lift the hood where it bolts up.. u can buy usdm version hoods that have scoops etc... and i suggest using hood pins because iv seen the hood fly up when the hatch ripped right off the hood
Old Apr 24, 2014 | 08:47 AM
BLU CIVIC's Avatar
Track Advocate
Old Apr 24, 2014 | 12:16 PM
davegt27's Avatar
which hood do you have?
Davegt27
Old Apr 24, 2014 | 12:47 PM
Creator's Avatar
<<and personally, find a real carbon fiber hood. so many fakes out there that have like 10 layers of clear coat before u hit the real cf.>>
This is also wrong. There are no full carbon fiber hoods for these cars. If your just looking for the space buy a fiberglass one. The CF hoods you see for these cars are fiberglass with one layer of CF, just for show. If you want to be technical, I guess that means that there is some CF in these hoods. The quality can vary, I would stick with VIS or Seabon.
FYI: I once priced out a true all CF trunk for a bimmer, it was 3.5k.
Old Apr 24, 2014 | 01:50 PM
davegt27's Avatar
Creator I hear you I got this from one company
Hello,
Hood pins are recommended for additional safety, but not required. The
VIS hood will install the same way a factory hood does, using hinges
and latch. Unless you purchase a dry carbon fiber, all other carbon
fiber hoods we carry (over 98% of them) are made with carbon fiber
laid over fiberglass. 100% CF hoods cost over $2000. ViS hoods weight
about 20-25 LBS. Thank you.
- Dee
Octane MotorSports
www.OctaneMotorSports.com
(916) 366-0230
M-F 9:00 AM - 5:00 PM
PACIFIC STANDARD TIME
for a long time I would not consider a CF hood since it was sort of smoke and mirrors, you’re buying a fiber glass hood with a few layers of CF and then they charge people some hi price.
but here is the other side of the coin let’s say I buy a fiber glass hood for cheaper, now I have to get that hood prepped and painted, but the carbon fiber hood I just put the thing on
So that's why I am going with CF
davegt27
Old Apr 24, 2014 | 03:03 PM
Nihilus's Avatar
This is excellent information. I actually never knew about the whole CF hood being fiberglass with a CF overlay. I was planning to get a CF hood and have it painted but now I'll just get a fiberglass. Here's a question though fellas. Do they make the JDM inverse for usdm front hoods in fiberglass?
Old Apr 24, 2014 | 07:11 PM
davegt27's Avatar
Inverse?
I found this site but I could not confirm quality or fitment so I am going to go with VIS
http://www.deftracing.com/fiber_glas...d_mainlist.htm
Years ago I bought a fiberglass hood from Raceon-USA.com for my Toyota. I custom ordered fiberglass because of the CF overlay thing.
I think they were run out of business because so many people got bad CF hoods from them.
Remember I can’t confirm quality or fitment
Davegt27
Old Apr 24, 2014 | 08:30 PM
Nihilus's Avatar
Inverse as in how the usdm middle section of the hood is creased low and the jdm is upwards.
Old Apr 25, 2014 | 02:09 PM
br8crumb's Avatar
blu civic care to explain the " nope "
what b series wouldnt fit lol? iv ran a b16/b18 ls and a b18c with a stock cf hood. like i said pick ur mounts and u wont have clearance issues
and he also didnt state what car hes in, but unless u plan to gangsta lean/custom mounts with a full size oem radiator it will hit the hood -.-
been there done that thanks
Old Apr 25, 2014 | 02:21 PM
br8crumb's Avatar
and creator u are correct, im implying that you can find cheap hoods that sun peel easily, show bubbles/blemishes, and tend to be wrapped instead of the cf being laced.
and for recommendation, seibon is the way to go, nothing against VIS though
Old Apr 25, 2014 | 03:45 PM
davegt27's Avatar
Thanks for the info
This is for an SCCA race car so it will be covered except for race days
And I bought a half size 3 core radiator
David
civiccrx21
Mar 11, 2005 08:09 PM
jdmDXrex
Jul 10, 2003 01:48 AM
crx_ef8
16
Jan 12, 2003 05:11 PM
90-CRXSi
Aug 28, 2002 08:02 PM
EFing8
13
Dec 3, 2001 03:30 AM
