Gas gauge no working.
Old Apr 22, 2014 | 01:16 PM
Vates's Avatar
Default Gas gauge no working.
It is stuck on a quarter of a tank... Is there a way to test the gauge alone to see if it can be fixed? supposedly the fuel pump in the car is new its an 89 crx si.
Old Apr 22, 2014 | 04:31 PM
d4g4m's Avatar
Default Re: Gas gauge no working.
It may not be the gauge. It may be the sending unit. The sending unit is forward in the tank. The pump is at the rear and has nothing to do with the gauge/sending unit. Check the connector under the storage compartment. Sending unit is under the access panel. But if I remember, I think the tank has to be dropped for removal.
Old Apr 22, 2014 | 04:35 PM
949's Avatar
949
if the fuel pump is new, most likely the reinstall may have damaged the sender unit in the gas tank. or it the wires connection may not be properly reattached.
Old Apr 22, 2014 | 04:58 PM
d4g4m's Avatar
Fuel pump/fuel level wire connector may not have been detached before dropping tank causing wire detachment.
Old Apr 22, 2014 | 05:04 PM
d4g4m's Avatar
Fuel pump/fuel level wire connector may not have been detached before dropping tank causing wire detachment. One side of plug is pump, the other side is sending unit
CeasarX
Honda CR-V & Element
Jul 15, 2018 05:34 PM
STREAMHAWAII
Jan 11, 2018 01:41 PM
drwoody
May 28, 2010 05:52 PM
yamaha6611
Mar 20, 2010 10:49 PM
traxxasx
Mar 16, 2010 10:21 AM
