02 Honda Accord random misfire
Old Apr 22, 2014 | 10:40 AM
jw 1's Avatar
Default 02 Honda Accord random misfire
Hello, I have a 2002 Honda Accord LX 4 cylinder F23A1 engine. When the car is at idle with the AC on I get a random misfire but NO codes. No check engine, no flashing or anything showing up when tested with the code reader.
The car has 130k on it and I recently replaced an o2 sensor when replacing the timing belt. The car runs fine at higher RPM's with no noticeable misfire when on the highway.
Any idea?
Old Apr 23, 2014 | 02:59 PM
jw 1's Avatar
Default Re: 02 Honda Accord random misfire
One more thing I forgot to add. The heater hose busted but most of the antifreeze went down but did manage to spray a few things. I did get a EGR code and cleaned the EGR valve hoping this would fix the problem. I did notice an improvement but every now and then it would misfire (low RPMs). It really doesn't show up unless I have the AC on and at idle.
Any ideas? Anyone???
Old Apr 23, 2014 | 11:45 PM
holmesnmanny's Avatar
Since it's happening at idle it's unlikely that it's egr related. When was the last time you replaced the cap, rotor, and plugs ? I would use seafoam to check for an exhaust leak.
PowerZree
Nov 27, 2018 01:10 PM
russ2169
Oct 23, 2009 03:22 AM
multitec
Feb 2, 2009 05:21 PM
BLKFLSH
May 26, 2007 10:39 AM
LostSoul
Oct 18, 2004 06:56 PM
