catch can
Old Apr 21, 2014 | 10:26 PM
chrisB18civic's Avatar
Default catch can
Well I made my own catch can today. I'm no pro so be gentle. Lol.
[IMG]http
I'm waiting on the 10an male fittings to show up so I can finish it.
Old Apr 22, 2014 | 08:34 AM
Pro-SeriesFab's Avatar
Default Re: catch can
Not bad
If you keep with the fabrication projects, it looks like you'll want a disc grinder and/or belt sander soon.
Old Apr 22, 2014 | 08:46 AM
Ya a belt sander would b awesome. We have disc grinders already. I work on semis so I just use what we have a lot of times you just have to improvise.
Old Apr 30, 2014 | 01:09 AM
Got the male 10an fittings welded on today.
Old Apr 30, 2014 | 04:40 AM
hoochhenry's Avatar
looks real well polish it it lets see the finished product
Old Apr 30, 2014 | 05:11 AM
Schister66's Avatar
Man U FTW
It isn't the prettiest catch can i've seen, but it doesn't look like its going to fall apart either
Function > form
Old Apr 30, 2014 | 07:32 AM
turbomaniac's Avatar
very nice..
almost prof job
Old Apr 30, 2014 | 02:04 PM
Here's one of the fittings for the back of the block. I'm to cheap to buy the ones on eBay for 40 bucks and I like making everything so I made my own.
Old Apr 30, 2014 | 05:17 PM
1sick4g63's Avatar
What threads are on the back? You just cut a bolt?
Old Apr 30, 2014 | 05:22 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
thats the only way to do it and not go broke, never believe that you have to pay a fortune for something when your own is just as good
Old Apr 30, 2014 | 06:03 PM
abnaasefmb's Avatar
Looks good. Rock it. Built not bought
Old Apr 30, 2014 | 11:18 PM
There actually the OEM plugs I drill them out then tig welded the 10an stainless fittings to them. The fittings were $8 a piece 16 total rather than 40.
Old Apr 30, 2014 | 11:24 PM
Well got it all done tonight and installed.
I also measured the block box hole in one of my spare blocks before work and picked up a 34.3 mm freeze plug at auto value for $.89 compared to one for 8.50 on sleezebay.
Old May 1, 2014 | 12:58 PM
PSI GUY's Avatar
Being that low it will not drain back well and will likely fill up and make a mess. I had one mounted there before and wasn't long changing the location.
Old May 1, 2014 | 02:51 PM
Its not a drain back setup I have a petcock in the bottom.
Old May 7, 2014 | 05:41 PM
10sec4door's Avatar
Petcock hehe, had to lol. Looks good wish I could weld
Old May 8, 2014 | 07:59 AM
hoochhenry's Avatar
nice idea is that bung you welded to stainless also the pice you welded the new fitting to ?
Old May 8, 2014 | 11:32 AM
Yes the bung is stainless. But the factory plug is not.
On a second note I have desided to change the setup already. I am going to be converting it to a evacuation kit I just need another 10an weld on and a 10an hose end. And am going to add a 6an to the can from the valve cover.
globlctzn
Honda Motorcycles
Feb 14, 2006 12:30 PM
Shwiggy
Feb 21, 2004 10:36 PM
S14
Jul 16, 2002 07:37 PM
