Intake Control Solenoid needed with AEM CAI v2?
Old Apr 21, 2014 | 08:29 PM
KaizenSenshi's Avatar
Default Intake Control Solenoid needed with AEM CAI v2?
Recently purchased a 1994 Accord EX, and have been performing all of the maintenance that the previous owner seems to have neglected. Was originally having the Idle Surge Issue common with these cars, and after cleaning the IACV, adjusting the FITV, and cleaning the EGR ports, the issue seems fixed.
So, today I installed an AEM Dual Chamber CAI, and there was nothing in the instructions provided on what to do with the Intake Control Solenoid (part 9 here)
Is this solenoid still needed?
If not, I know that I will need to plug the line to keep from having a vacuum leak. Should this line be plugged at the Engine Mount Control Solenoid Valve on the driver's side of the throttle body? Or, should I just run a straight vacuum line from the IAR Vacuum Tank to the Engine Mount Control Solenoid Valve?
Any advice that can be shed on this issue would be greatly appreciated.
Old Apr 21, 2014 | 11:23 PM
holmesnmanny's Avatar
Default Re: Intake Control Solenoid needed with AEM CAI v2?
You completely remove it and cap off the nipple on the IM that the vacuum line went to.
Old Apr 22, 2014 | 02:58 AM
Thanks for the answer. Heading outside to take care of this right now.
Happy Gilmore
Nov 7, 2008 08:15 AM
MilanoLude
Sep 24, 2007 03:19 PM
JBirch_97Prelude
May 6, 2007 04:07 PM
boonacka
Sep 5, 2002 03:24 PM
IDE RaiD
Aug 22, 2001 11:58 AM
