96 accord exr cylinder 2 and 4 misfire cause?
Old Apr 21, 2014 | 03:36 PM
Joesarfi's Avatar
Icon3 96 accord exr cylinder 2 and 4 misfire cause?
i have a 96 accord exr with arround 180,000kms on it and the engine light randomly came on and flashed for a few seconds and then went solid. i plugged a scanner into it and found out that cylinder 2 and 4 had misfires and after i cleared them a week later the engine light came back on and im wondering what the cause of that might be?
Old Apr 21, 2014 | 03:41 PM
kevogsrek's Avatar
Default Re: 96 accord exr cylinder 2 and 4 misfire cause?
switch the coil pack 1 and 3 and see if the misfire moves. if so then you need two packs. if not maybe plug or injector or cylinder problem.
Old Apr 21, 2014 | 03:47 PM
95accordCE6's Avatar
96 had a distributor and one coil. Check the plugs for proper gap and contamination, check the wires, and check the dist cap for any damage or corrosion or arcs
Old Apr 21, 2014 | 03:58 PM
kevogsrek's Avatar
oh yea that's right my bad. that's def right
Old Apr 21, 2014 | 11:49 PM
holmesnmanny's Avatar
My first guess would be the egr ports are clogged. Fairly easy to fix on your car compared to most hondas. Google "eric the car guy honda egr cleaning".
Old Apr 22, 2014 | 03:47 AM
Joesarfi's Avatar
Icon6 Re: 96 accord exr cylinder 2 and 4 misfire cause?
thanks guys this has been helpful
ill keep u guys posted
camaroprelude
Nov 23, 2014 05:04 PM
FreshCD5
Dec 1, 2010 03:39 PM
nickoz
Feb 24, 2008 05:59 AM
khenning
Oct 14, 2004 12:12 PM
