Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
vibration 22-30 mph.... wtf help
Old Apr 18, 2014 | 07:35 PM
hybridb18's Avatar
Default vibration 22-30 mph.... wtf help
Here's the deal, I just picked up a 2004 6 spd 120k about a month ago.... since then I have been doing some regular maintenance, oil, trans fluid, brake/clutch fluid, coolant ect. Ive been getting some nasty vibrations.... I also just put 2 new axles in the car, which solved 90% of the vibrations. But I am still getting a vibration between 22-30mph. It doesn't matter what gear (2nd, 3rd, 4th) but it's only Under Load. Coasting, or in neutral it will not vibrate. Tonight, for ***** and giggles I rotated all 4 wheels front to back. Nothing.... same issue. All the ball joints seem good, no play in the wheel bearings. Rotors and pads are good. Looked at all the motor mounts, nothing noticeably bad... I'm outta ideas here Suggestions?
Old Apr 18, 2014 | 07:39 PM
hybridb18's Avatar
Default Re: vibration 22-30 mph.... wtf help
Havnt done an alignment, but the thing drives straight as an arrow. Steering wheel is straight. Newer Goodyear tires. No noticeable tread wear, even, no burs ect..
Old May 16, 2014 | 06:47 AM
Lwelds's Avatar
http://www.heeltoeauto.com/news/04-0...and-fixed.html
You should find this really helpful
Old May 16, 2014 | 07:27 AM
Lwelds's Avatar
Old May 20, 2014 | 10:09 AM
cl9 jon's Avatar
Could be the axles actually... are the aftermarket or OEM? Aftermarket ones usually vibrate
LCA bushings may need replaced...
eric5984
Honda CR-V & Element
May 2, 2019 10:47 AM
wgbm92
May 21, 2011 02:03 PM
teewhy55
Dec 22, 2004 09:36 PM
slowassR
Sep 24, 2002 12:48 PM
