idle issue d16z6 manifold on d16y7
Old Apr 18, 2014 | 12:24 PM
freddie_stanced's Avatar
Icon2 idle issue d16z6 manifold on d16y7
hey guys im having a bit of a hard time trying to figure this out, i just got me a ek hatch with a d16y7 bone stock motor only mods are a z6 manifold which i know is the dumbest thing to do on a d16y7 but i got the car that way its throwing a code 14 for iacv went and bought a new one replaced it reset ecu and it still throws the code my idle jumps from 1k to almost 2000rpm then its just get stuck at 1500 kinda like a little mini 2 step lol my issue is what i can i do to resolve the high idle it has the y7 throttle body so im using the 3 pin connector instead of the 2 pin for the z6. The iacv on the manifold is blocked off so im not getting a leak from there i ordered a throttle body gasket to see if thats the issue but havent had time to put it on . also i am running the stock ecu it has a z6 fuel rail with y7 injectors and the throttle cable is correct so i dont what it could be need some help out there guys anything would work right now
p.s also forgot to mention from time to time when i put the ac on the idle will stop surging and sit right a 1k rpm then as soon as the compressor kicks off it idle up and down again and idea ?
Old Apr 18, 2014 | 08:00 PM
Default Re: idle issue d16z6 manifold on d16y7
bump
Old Apr 18, 2014 | 08:36 PM
nub's Avatar
nub
Actually switching the intake manifold is far from dumb. The Y7 intake is one of the worst MPFI manifolds Honda did.
A common problem when the manifold is swaped and the 3 wire TB is reused is the TB gasket. The TB has a specific gasket and with the wrong one you'll have a big vacum leak.
Notice the right side of the gasket in the two pics.
Old Apr 19, 2014 | 06:31 AM
so i should use the one with the rivets on the side for the connector since i will be using the 3 pin connector correct ? i ordered the stock y7 tb gasket from advanced was i wrong ?
Old Apr 19, 2014 | 10:18 AM
bump thanks to nubs i figured it out tb gasket was wrong put the correct one now car idles perfect ! thnks bro
Leviatard
18
Oct 30, 2014 09:28 AM
TomCurllyFry
Nov 29, 2012 04:02 PM
snatch
40
Mar 29, 2011 01:25 PM
Ahknodd
Dec 16, 2008 05:34 PM
gray89si
21
Oct 11, 2005 06:33 AM
