Garage Clean Up. JDM/USDM/Aftermarket/OEM.
All Sales are Final
No Returns or Refunds
Local Pickup Always welcome
Reasonable Offers will be considered.
Prices do not include shipping or paypal fees unless stated.
Contact - Infamousavi@gmail.com
ProSport EGT Gauge - $100.00
Amber/White Series
Race Engineering 84MM Piston Ring Kit for CP Pistons - $100.00
(should work with other brands, contact race engineering for more info.)
OEM Honda Rod Bearing Set - $80.00
GM 3 Bar Map Sensor - $20.00
P09 OBD1 Non-Vtec ECU - $100.00
P2E OBD2B Non-Vtec ECU - $100.00
OBD2B Civic EX Automatic ECU - $100.00
HALMETER AF30 - $30.00
OBD2A - OBD1 Jumper Harness - $50.00
Auto Meter 96-00 Gauge Pillar Pod - $20.00
K24A2 Knock Sensor w/Clip - $70.00 Each
B-D-H Knock Sensor - $70.00
(comes with clip/not pictured)
Energy Suspension 16.18110 G - $120.00
Brand New in box/ Bags opened for inspection)
T3/T4 Turbo Drain Flange with -8AN 90* Fitting - $30.00
XRP -8AN Fitting - $5.00
BG Fuel Cell Bulk Head Fitting - $15.00
(quick efficient was to tap your oil pan for a turbo drain line without welding)
-3AN Steel Braided Oil Line w/ T Block and Oil Pressure Switch - $25.00
(missing NPT to -3AN fitting for connection)
K24A2 Vtec Solenoid Assembly - $60.00
99-00 Civic Climate Control Switches - $40.00
96-00 Civic Manual Transmission Bracket - $50.00
Auto Meter Pro Comp Ultra Lite Pyrometer - $100.00
Greddy Profec B Spec II Boost Controller - $300.00
Golden Eagle Pro Series Fuel Rail with Blox Fuel Pressure Gauge and -6AN Fitting - $120.00
(setup used with external fuel pressure regulator, B Series Motors)
EG/DC OEM Smoked Side Markers - $35.00
JDM Integra Type R Faux Carbon Interior Pieces - $120.00
driver vent with sunroof switch delete,cruise control delete ,ash tray and lighter assembly ,cupholder,shift boot with bezel and console.(all parts seen in picture)
94-01 JDM Integra Headlamp Fog Light Covers with hardware - $25.00
(these tend to get damaged on JDM Headlmaps)
98 Integra Front Calipers - $100.00
96-00 Civic Air Bag - $40.00
(dark gray)
BRAND NEW BLOX 20 pcs Lug Nuts Black - $55.00
B18C Head Bolts - $50.00
OEM Clutch Master Cylinder - $25.00
(fits 94-01 integra, 92-00 Civic)
Integra Type R Cruise Control and Sunroof Switch Block Off Plates - $25.00
(both, will fit ALL 94-01 Integra)
96-00 OEM Fog Light Switch - $30.00 each. (light gray) (2 available)
Sparco Side Mounts - $200.00 (Never used)
RBB Cam Gear - $70.00 (65K Miles)
K24A2 Valve Springs, Spring Seats, Spring Retainers and Keepers - $60.00
K24A2 Head Bolts - $60.00
K20A2 Diff - $125.00 (has less than 40K Miles on it)
94-01 Integra or 92-95 Civic Fog Light Switch - $30.00 (used in arm rest)
94-01 Integra Shock Forks - $40.00
Auto Speed Sensor with clip (pig tails) - $30.00
SOHC / D Series Auto Starter - $50.00
Air Intake Temp Sensor with clip (pig tails) - $30.00
OBD2 B Series Alternator with Brackets and Clip (pig tails) - $80.00
Mishimoto Universal Radiator, Part# MMRAD-UNI-26 - $225.00
Brand new in box, only opened for test fitting. has warranty card etc.
More Parts will be added. Thank you for looking.
Please bump if viewed.
Amber/White Series
(dark gray)
Might take those lugs off your hands just waiting on my wheels to get here and just a heads up if the head studs are used they can't be re used again glws
