bearing clearances
Old Apr 17, 2014 | 06:27 PM
goat86's Avatar
Default bearing clearances
I just checked my bearing clearances and there all .0010in and I have std acl bearings what bearing should I get to have at lest .0015in clearance I no that honda has different ones and acl is the same as the green honda bearings please help
Old Apr 17, 2014 | 07:17 PM
br8crumb's Avatar
Default Re: bearing clearances
if u have never done bearings before.. i highly recommend going to a shop... if ur surfaces are clean and within spec then ur looking at like 100$ labor + bearings cost
this is just my 2 cents though.. every block iv built iv had them match rod bearings with oem bearings to spec because they usually are all different and u can pick how tight/loose to make, and then main/thrust i use acl or king which are 1 size standard all the way through.
bearings arnt something to just guess on and its hard to explain whats correct because every block/crank is different. give urself the peace of mind with a shop for a extra 100-200 ontop of bearing cost. most shops u can give them the acl set and they can use what they can out of it.
Old Apr 18, 2014 | 08:46 AM
Pro-SeriesFab's Avatar
First off, what are you using to measure clearance?
Old Apr 18, 2014 | 08:48 AM
goat86's Avatar
I see what u mean but I got enough money in this thing already I was reading my manual and it says 1&5 can be .0007to.0014 and I have .0010 on all of them I should be good right? 2,4&5 r supposed to be.0010 to .0017
Old Apr 18, 2014 | 08:50 AM
goat86's Avatar
Plastic gauge green
Old Apr 19, 2014 | 12:00 AM
goat86's Avatar
So is .0010 good for all the clearances
MadVTI
Oct 4, 2009 05:47 PM
killerpenguin21
Jul 12, 2006 07:20 AM
92hatchattack
Jun 7, 2005 09:21 AM
db2integra
Sep 20, 2004 08:25 PM
bearingburner
Mar 2, 2002 06:57 PM
