94 Honda Accord stops when braking/stopping.
Old Apr 17, 2014 | 12:58 PM
thefranchise03's Avatar
Default 94 Honda Accord stops when braking/stopping.
Recently, I've had a problem when I stop at the light or start to slow down. The engine completely shuts down and I have to start it again. But once I start it and try to go reverse or forward, it shuts down again. Any idea what the problem is? Thanks in advance.
Old Apr 17, 2014 | 03:38 PM
lazlong's Avatar
Default Re: 94 Honda Accord stops when braking/stopping.
Start with getting any trouble codes: http://check-engine-light-codes.blog...retrieval.html and post back with the specific codes.
Old Apr 17, 2014 | 07:43 PM
MAD_MIKE's Avatar
MM Gruppe B
Any idle issue problems? What happens when the car is at idle and the A/C is turned on?
Old Apr 17, 2014 | 11:06 PM
holmesnmanny's Avatar
My first guess would be the fuel strainer is clogged.
I would get a $20 fuel pressure tester kit from Harbor Freight and hook it up with the gauge facing the driver at the windshield with the hood gently laid on top of it and see what the fuel pressure looks like when it stalls.
Old Apr 18, 2014 | 12:59 AM
You mean when it stops? It usually shakes a lot, probably the engine.
Old Apr 18, 2014 | 04:19 AM
MAD_MIKE's Avatar
MM Gruppe B
When the engine is warmed up and idling, what does it do. Not after a stop, just at idle.
What happens when you are at idle and turn on the AC?
If it is low or stumbling, remove the rubber air intake hose to throttle body.
Use a clean rag with some TB cleaner on it and remove and coking buildup around the inside of the TB.
Check to see if this improves the idle quality. Do not just spray the cleaner into the TB. Wipe down the throat of the TB and the edge of the TB butterfly.
Joshua Drush
Dec 15, 2015 01:49 AM
jorgep82
Nov 18, 2013 12:15 AM
epichonda91
Jul 18, 2013 11:06 AM
dustin16
Mar 9, 2006 06:14 AM
