Cooling fans
Old Apr 17, 2014 | 05:36 AM
ODbuilt's Avatar
Default Cooling fans
My cooling fan turns on as soon as I start the car , is that bad ?
Old Apr 17, 2014 | 06:40 AM
KevinEF7's Avatar
Default Re: Cooling fans
With the engine cold it still does that? not good
Or is the engine already hot and just ran, then yes its ok
Old Apr 17, 2014 | 08:14 AM
ODbuilt's Avatar
When I first turn the car on , cold , the fan turns on . What could it be ?
Old Apr 17, 2014 | 08:16 AM
24TEN's Avatar
PHANTOM MENACE
It's a simple circuit if you back track it. There's a switch that allows current to flow to a relay. Check the switch, check the relay. See what you come up with.
Old Apr 17, 2014 | 09:43 AM
br8crumb's Avatar
is ur AC on... that usually triggers the fans regardless of engine temp
Old Apr 17, 2014 | 06:57 PM
ODbuilt's Avatar
My ac is off , my friend said it might be doing it because there's only one fan and it turns on as soon as you start the car because there's no other fan
Old Apr 17, 2014 | 07:11 PM
br8crumb's Avatar
thats a horrible theory lol. either the coolant temp sensor is bad and it turns the fan on as soon as it gets power, or u have a wiring issue like stated above that needs to be traced
acg21
Honda Civic (2006 - 2015)
Jul 2, 2016 08:11 AM
19 crx 89
10
Aug 26, 2010 12:38 PM
Flatlandz
Honda Civic (2001 - 2005)
May 2, 2010 12:32 PM
Memnoch
Jul 11, 2008 07:47 PM
HX_Guy
May 31, 2002 08:38 AM
