EX Brake and Caliper Swap
Old Apr 16, 2014 | 07:41 PM
BombSquad91's Avatar
Default EX Brake and Caliper Swap
I've done a lot of research and still can't find an answer. I'm running a 14" rim. I don't want to go to 15". I want to upgrade the calipers and rotors to the calipers and rotors from a 90-91 EX. Can I do this and still keep a 14" rim. Thanks in advance.
Old Apr 16, 2014 | 08:49 PM
Riceburner247's Avatar
Default Re: EX Brake and Caliper Swap
Yes. I have the EX setup on my car and I run 14" rims. They barely clear, but it's fine. You'll need the EX spindles as well.
Old Apr 16, 2014 | 09:16 PM
I saw a thread that said the EX calipers and rotors would fit on the EF spindles.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/easiest-brake-upgrade-you-never-knew-about-details-inside-1171175/
Old Apr 16, 2014 | 10:59 PM
The link you posted isn't an EX brake upgrade. That's some sort of hybrid/ITR style brake upgrade.
I'm telling you that a true EX brake upgrade fits under 14" wheels.
Old Apr 16, 2014 | 11:01 PM
I believe you. I just thought I didn't have to change the spindles.
Old Apr 16, 2014 | 11:21 PM
Tyson's Avatar
yes of course you have to change knuckles.
Old Apr 18, 2014 | 11:46 AM
clubworkz's Avatar
I have read that hx rims won't fit with out using an angle grinder on the edge of the calipers.
ludesrv
Feb 18, 2008 05:31 PM
efhonduh
10
Jul 8, 2007 10:15 AM
pd0019
Honda Civic (2006 - 2015)
11
Jan 26, 2007 03:24 AM
steronz
Dec 19, 2006 04:54 PM
carracr625
13
Jul 27, 2005 05:40 PM
