Honda CR-V & Element 2WD & 4WD Element & CR-V
Cruise Control Problem 2002 CR-V
Old Apr 16, 2014 | 07:26 PM
Genaro47's Avatar
Default Cruise Control Problem 2002 CR-V
It seems that the Cruise Control on 2nd Gen CR-V suffers from a glitch. Overheating,low battery voltage or Gremlins seem to make everyone's Cr-V with a cruise control cut out after 40-50 minutes. I have replaced the foot pedal control unit with a new OEM Honda one, but still cuts out after 40 minutes or so. Has anyone found out the definitive solution? I have read that even replacing the control unit and the actuator unit did not solve the problem. Thanks.
Old Apr 16, 2014 | 09:41 PM
tony_2018's Avatar
Fish Twig
Default Re: Cruise Control Problem 2002 CR-V
Ever thought of finding the oem helms repair manual to troubleshoot this instead of throwing money at it?
Old Apr 17, 2014 | 03:40 PM
Genaro47's Avatar
Thanks for the suggestion. I have the Honda OEM manual that I obtained and downloaded from a former Honda Technician. I was just hoping somebody on the Forum had solved this problem before.
Does the Helms manual say anything about Cruise Control troubleshooting?
Old Apr 21, 2014 | 05:09 AM
Genaro47's Avatar
I think I found the problem source. The intake rubber hose at the throttle body had a split under the big clamp. Maybe when I hit a small bump on the road with the cruise control engaged, the split opened just enough to overcome vacuum and turn off the cruise control. I repaired with silicon, but ordered a new one from Honda.
lynda1781
Aug 25, 2014 04:56 PM
Tim Ironmonger
Jul 18, 2012 01:58 PM
Jonathan_ED3
Mar 28, 2006 07:38 PM
