P8R, Crower and some OEM
Message me if you're interested in anything! Prices DO NOT include shipping
OEM optional Stanley side markers - Sold
P8R head - Sold.
Crower 403-2b cams - Sold
Integra shock forks - Sold
NA b-series valve cover - Sold
Integra Front and rear calipers - $25 per caliper
-Rear calipers are NOT seized as is so common with Integras
-Front Driver, front passenger and rear driver still available
Integra rear dust shields - $5
Integra 14mm rear sway bar - $15
Misc items: - $4 ea
List:Yamada oil pump w/ bolts
Water pump w/ bolts
OEM flywheel bolts
Oil pickup hardware
Ls Oil girdle w/ bolts
Crank seal cover with bolts
Crank sensor with hardware
Knock sensor
Oil pan bolts
Ls Lower timing belt cover
Ls upper timing belt cover
With hardware
Oil dipstick
Random mount with hardware
Drivers side b series mount
Alternator mounting bracket
Timing tensioner spacer and bolt
Ls headstuds
OEM Integra springs and shocks -$60
-The rear shocks were blown and replaced with Monroe shocks from Advanceauto
Integra stock mounts (fit EG)
-Trans mount is torn, these are a great candidate for someone who wants to window weld the mounts (ghetto solid mounts!)
Strongarm Integra hatch shocks - $5
-Not the strongest, but they work
Russel stainless steel clutch line - $10
-This line replaces the soft rubber line from the hard line that leads from the master to the slave
LS cams (No gears!) - $10
LS cams with gears - $20
94-01 integra trailing arms -$25
-Drivers side still available
94-01 rear LCAs- $20
94-01 manual integra mounts - $10
rear mount is torn
OEM b series alternator with AEM trupower pulley - $70
P8R head - Sold.
Misc items: - $4 ea
Water pump w/ bolts
OEM flywheel bolts
Oil pickup hardware
Knock sensor
Oil pan bolts
With hardware
Oil dipstick
Ls headstuds
rear mount is torn
JDMImporter
May 15, 2014 01:31 PM
crxfornow
Feb 10, 2013 11:39 PM
