Tranny fuild change - is this ok?
They want you to keep the car level so that you get the right amount in the tranny. Pour tranny fluid in on a level car until it spills out of the tranny fill hole. When it stops leaking out of the fill hole, put fill plug back in....voila, tranny fluid change with the correct amount of fluid.
Or you can always just add in 2.2 litres of tranny fluid with one of them pumps. The Honda MTF bottles have a level indicator on the side of them so you will know how much 2.2 litres is.
But there should be enough fluid in there right? That is what I am concerned with right now.
[Modified by sackdz, 9:35 AM 10/30/2002]
I highly doubt that just jacking up the front will change the amout od fluid that gets in there. The drain plug is on the side of the tranny if memory serves. So what if you're out by .2L .
I thought we were talkin' 'bout jacking up the back.
Well if you really wanna get some fluid in there, drain it with the car level, and fill it with the only the back lifted 8^)
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
phateless
Jun 23, 2009 10:39 AM
mikeintegra93
Jan 9, 2009 04:12 PM
Elwuudz
Jan 15, 2006 07:54 PM
