Short Shifter
Old Apr 15, 2014 | 06:41 PM
kn1ghtt's Avatar
Default Short Shifter
Hey,
I own a honda civic coupe lsi 1995, and i wanted to install a short shift gearbox the problem is that i dont undestand anything of brand parts. Any advices?
Old Apr 15, 2014 | 07:35 PM
98civdx's Avatar
Master Detailer
Default Re: Short Shifter
It really is a shifter, some are different/better than others. What's a price you are comfortable with?
I have a Skunk2 and I like it.
Old Apr 15, 2014 | 08:22 PM
B_Swapped93's Avatar
K tuned adjustable FTW
Old Apr 15, 2014 | 08:40 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Is OP talking about close ratio gears?
Old Apr 16, 2014 | 01:22 AM
eghatch9295's Avatar
Stancetard Hate Monger
id pass on the k tuned. reinventing the wheel= stupid. i dont want multiple parts where a simple lever should be. ive had skunk2 and b&m. both are nice.
Old Apr 16, 2014 | 04:57 AM
They're more expensive yes but well worth it, even more worth it if you do time attack auto-x etc.
Old Apr 18, 2014 | 08:19 AM
kn1ghtt's Avatar
im looking for faster shifts. the problem is that requires alot of disassembly to place the new shift and i dont know nothing about that.
Old Apr 18, 2014 | 08:26 AM
24TEN's Avatar
PHANTOM MENACE
It's been years since I've had to remove mine but if I remember correctly all I did was remove shift **** so the shifter can fall through it's opening, two bolts underneath the car holding the shift linkage to the tunnel, and I believe two more hold the two linkages together, and last the bottom bolt holding the lower linkage to the shifter. That's not alot of disassembly in the grand scheme of things (unless you are running something that required a cable shifter be installed and didn't mention that in your first post).
dr_latino999
22
Jan 15, 2007 04:14 AM
dxhatch93
Feb 7, 2006 05:19 PM
tvman
Jul 14, 2005 11:36 PM
Irishweird00
Aug 12, 2003 01:47 PM
carsaregood
13
Dec 3, 2002 08:41 PM
