92 Civic EX won't start, fuel pump doesn't prime
Old Apr 15, 2014 | 12:47 AM
yossi6780's Avatar
Default 92 Civic EX won't start, fuel pump doesn't prime
I have honda ex 92 and i didn`t hear the sound of the main relay assy work,i wate about 15 min` after that a turn the swich on and i hear the relay work and the car start on,
can same one help what its can be the problem?
i check the voltage in the relay and i don`t undestand what`s the problem?
Old Apr 15, 2014 | 01:24 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: honda ex 92 d`ont start
Repair or replace the main relay
http://techauto.awardspace.com/mainrelay.html
Old Apr 20, 2014 | 11:49 PM
yossi6780's Avatar
thank you, i will replace the main relay.
Old Jul 24, 2014 | 11:17 PM
yossi6780's Avatar
Default dont start on
I dont here a slight humming noise that coming from under the rear seat when i turn the ignition two clicks,what its can be the problem?
Old Jul 25, 2014 | 02:29 AM
andoxviii's Avatar
Default Re: dont start on
Assuming you are being serious right now...
This means your fuel pump isn't priming. There are many possible causes of this:
1. fuel pump is bad
2. main relay is bad
3. ECU is bad
4. the wiring between any of the above is bad
Old Jul 25, 2014 | 03:28 AM
grumblemarc's Avatar
The Grumpiest
No progress on this issue in 3 months?
Read this.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Old Jul 25, 2014 | 12:09 PM
Former User's Avatar
You are allowed only one thread per topic, and car information is absolutely required for all tech threads. Please read the forum Rules sticky.
Just2Bar
May 19, 2015 03:59 PM
uszcrx
24
Sep 9, 2006 01:05 PM
tomu06
Aug 7, 2006 12:02 PM
mgries
Sep 19, 2002 07:15 PM
mercury
Jul 16, 2002 07:15 PM
