Clutch master and slave HELP!
Old Apr 14, 2014 | 12:54 AM
nytmrchr's Avatar
Default Clutch master and slave HELP!
howzit, i own a 01 dc2 with a b16a2 drop. mk so i've just finished installing my Master and Slave cylinder. Topped off the Reservoir and had my friend pump the clutch about 4 times as I opened the bleeder from the Slave (been doing this for 30mins now). Thing is nothing is getting sucked up from the reservoir. There are no leaks coming from my hydraulic lines, and I've doubled checked my work making sure I've installed everything to the T. Also as i cracked open the Line that connects to the master, no fluid comes out. I've hear about "bench" bleeding the Master prior to installation but I've seen other Videos of people just installing their cylinders and either Gravity feed or just pumping the clutch until you feel pressure. Need help ASAP this is my only means of transportation
here is the procedure i went by:
-pump clutch 4-5 times stop
-release the bleeder, then close
repeat..
Old Apr 15, 2014 | 03:38 PM
jorge1190's Avatar
Default Re: Clutch master and slave HELP!
Bench bleed the master. Disconnect the line going to it then fill it up and wait for the fluid to start coming out. After you bench bleed let the slave gravity bleed by opening the bleeder and connecting it to the master cylinder. Once you see fluid have someone pump the clutch until it builds some pressure, hold it down, open the bleeder, and close it again with the pedal still to the floor.
Old Apr 15, 2014 | 07:55 PM
NMKTUNING's Avatar
jtran21
Honda Civic (2001 - 2005)
Mar 11, 2013 08:32 PM
reenie10_73
Jan 28, 2010 08:40 PM
R81_DC2
Aug 14, 2009 08:54 PM
delsolsi193
11
Apr 7, 2009 09:46 AM
AndyD
Mar 5, 2003 08:32 PM
