Aftermarket Coilover Suggestion
I have owned a couple cars but this is my first project.
I have some parts coming and my next goal is to tackle the ride height but i havent done much research on coilovers for this car (1990 Honda Civic DX Hatchback btw)
Anyone got any good suggestions. I have read into D2, Tein, Raceland, but nothing is really sticking and suggestions on what to look into
Forget all the ones you have listed.
There are really only 2 good choices under $1k: Progress or Koni/GC
Use the search function to find more info on each one and to decide which is best for you.
I don't know where you got your info, Progress makes coilovers, and Koni/GC is a strut and coilover sleeve setup that allows you to change ride height.
Lol personally changing ride height by lowering the spring is not an option. Having a spring moving everywhere when the car is lifted wont pass any car inspection lol.
how else are you going to adjust ride height? ******* with preload only leads to problems, full coilovers are over OP's price range of $1k
more importantly WHILE THE CAR IS MOVING, the spring will be in the correct position doing its job as long as you're not ******* slammed.
but what do I know
what inspections do you have where they lift the car?
but what do I know
but what do I know
Learn how suspension works.
Preloading a spring wont get you lower... loll with another coilover you should have a third ring that allow you to make the strut longer or shorter. THATS how to adjust a ride height.... getting your spring lower on your strut with koni or progress will get your damper to a wrong travel span or to simply no travel span if you go too low.. So if your spring rate is like 200-300 with koni and you slam it as ****, itll result to a shock body hit the shock head and boom damage to your damper. Thats my opinion. They are just not made to adjust ride height. Thats about the same as cutting your god damn oem springs...
Thanks guys... i think lol koni and progress gotcha. Ya i was originally gonna get an eg hatch, but i saw this ef and fell in love so i got it no regrets. So all the info i have is based off an eg build. even though there isnt much difference between the two (if any).
And im looking for somehwhere around a 2 inch drop...
I was going to say Progress CSIIs are the best bang for the buck performance wise, and I think most will agree. $605 shipped for adjustable drop coils with spring rates of your choosing.
edger8cer
Suspension & Brakes
Nov 6, 2005 11:50 AM
CXHatchback
Oct 1, 2002 09:23 AM
